Results 11 to 20 of 25
Thread: Could a bent spoke make your disc feel warped?
    paulc's Avatar
    paulc is offline Senior Member
    Nov 2009
    Carshalton,London, United Kingdom
    Re: Could a bent spoke make your disc feel warped?
    The bike was a 250 and only 17 months old explain that ? I cant.
    And no I am not concerned about cast wheel failier otherwise I'll have to wait until they devise some replacement for the wheel.
    Cheers Paul
    Warthog's Avatar
    Mar 2007
    Quote Originally Posted by 1gear1brake View Post
    When you removed the disc, did you clean the areas on the hub where the disc fits? If there is any contamination between the disc and hub will make a true disc run wonkey.
    Didn't clean that area, per se, but did look as I wondered if the bolts were the cause: no eveidence that I remember...
  4. #13
    Warthog's Avatar
    Mar 2007
    What about sticking caliper pistons? sticking them releasing then slitcking etc?
    Clutching at straws, aren't I?
  5. #14
    AlanH's Avatar
    Bristol, UK
    Quote Originally Posted by paulc View Post
    So what did the manufacturer say when it was investigated? What bike was it? What failed? Hub? Spokes? Rim? It sounds like a manufacturing fault.
  6. #15
    AlanH's Avatar
    Bristol, UK
    Quote Originally Posted by Warthog View Post
    Yep. It's a warped disk. If the caliper is binding slightly and the disk gets hot, that's often enough to warp it.
  7. #16
    Curzon is offline Member
    Oct 2009
    Chester
    Not at all. That was my thought also!
    Are you sure the pulsing is only under braking? or is it there all the time but only more noticeable under braking? I would have thought that a bent spoke would make the wheel out of true / balance which should be noticeable all the time, but maybe worse under braking.
  8. #17
    Warthog's Avatar
    Mar 2007
    Quote Originally Posted by Curzon View Post
    Yup. I've had warped discs before and I knew the first time I braked on this one. Kinked spoke was new to me and I thought "maybe!!...."
    Riding along: nothing out of the ordinary, any pressure on the lever and pulsing begins:
    Harderbraking: spronger pulsing, faster speed: faster pulsing...
    Oh well....
  9. #18
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    Head bearings?
  10. #19
    boroboy is offline Member
    Jan 2010
    croydon
    Oh well....
    If you have had the disc off and had it on a flat surface and a straight edge across it then you can rest assured it aint warped, if its running true to the wheel and hub then its fitted correct, as long as your caliper is not loose then thats it what more can you do....... except check the simple bits, like are the pads and disc clean, give the disc a scrub with a bit of sand paper or emery stick another set of pads in...give it a go....
    So the answer to your question about a bent spoke etc.... I would say no.
    faster speed: faster pulsing... .... does this mean that without the brakes being applied its still pulsing. ?????
  11. #20
    Dee Duble Yuh's Avatar
    South Wales, UK
    What caused the spoke to bend? Maybe that has damaged the disc too. Or maybe the wheel is no longer true and the pulsing is caused by the whole wheel wobbling
    DW (Dave)
    "Let's ride motorcycles!"
  1. Video- Warped Brake disc easy change
    By RodYork in forum Africa Twin
    Last Post: 16-11-09, 02:08 PM
  2. Warped disc and chattering pads?
    Last Post: 16-09-09, 06:44 AM
  3. Bent Spoke
    By the_earlobe_of_doom in forum Transalp
    Last Post: 02-09-08, 08:12 PM
  4. Rear brake disc rotor possibly warped
    Last Post: 20-04-05, 01:27 PM
