Don't use a cigar lighter socket to jump start - it will end in tears. The only way to jump start a vehicle is to connect the healthy car/bike/battery direct to the sick car/bike - positive (red) to positive and negative (black) to negative (or a suitable earth point).
You could rig up a special socket using battery lead cable connected direct to the battery with a suitably rated connector on the other end or just put in an easy to reach place (insulated and not touching each other obviously!!).
Fix that problem and the other problems disappear.
