you need one of these from vehiclewiringproducts
fuse/relay block - Honda Trail Bike Forums
wired direct to the battery with its own in line fuse and switched from the headlight relay switching feed, (which is easiest as its right there in the bottom of the main fuse box), the instrument light feed, or tail light. have a look in the wiki to see how to wire from the fuse box
Fitting heated grips - Honda Trail Bike Wiki
this will give you three seperately fused accessory points without having loads of wires coming off the battery. ive got the horn, heated grips and front accessory socket on mine, and still got a spare.
