Re: Welding. How easy is it?
Originally Posted by
Warthog
Thanks all.
Basically it's a toss between the Arc and Mig.....
Jenna:
I agree on the ally weld front. I've found someone locally who'llweld pretty cheap to the point that a custom made 4mm ally bashplate to replace the TA600 plastic original could come to about £70!!!
tell me more about this bash plate
Sorry late to this one.. again..
I was taught to weld as an apprentice.. But did not go down the coded welder route.. We all just did a common first year in our apprenticeship before going into our differing engineering disciplines, so I ‘thought’ I could stick. & Gas weld.. I decided to make some simple steel railings for the house a few years ago.. (20mm box section with 3mm infill), so I bought a cheap stick (coated welding rods ) welder and set about this simple task…… made a complete mess of it.. Found out there was a beginners welding course at the local school so condescended to go ….sorted
What I had forgot is that welding is the last part of the fabrication process.. You need to ensure you have prepared and jigged and set up and tacked what you intend to weld.. And only then do you strike an arc… I had also forgotten that as an apprentice I had labelled a few folk as neeps as they could not grasp the subtleties of the maths needed for instrumentation and power systems.. But could weld like me ….
Welding is not a skill… I met one of the neeps a year later, we were third year apprentices then, I had been on various course and plants and was very skilled.. He had ‘just welded’ I had to sort something on the plant and the simple welder was below me on the ‘unit’ he was welding on to a pressured line doing a HOT hot tap…
Welding is an art… ALL the work he had done was checked and checked . He was a perfectionist … and as a coded welder is only as good as his last weld qualification.. Shame doctors et al don’t go down the same route…
Bottom line for us mortals.. If we want to stick something together.. Use stick J
You want a good job.. Get an artist to do it..
Or fill it fill it grind it out and paint it
XRV 650R RD03 1989
The Longest Day Rider 6
