Hi!
Forgot to unlock the fron disc brakes at my "Africa Twin"
one disk is twisted.
Runout acordinf to honda is 0.3mm
(I have a dial guege and arm and magnetic base for the job)
is there a way to save the disk? it is new!
thanks!
Hi!
thanks!
Don't know what year your bike is, but disks are your life.
Honda XRV 750 X/Y RD07 Africa Twin 99-03 Replacement Motorcycle Parts at Wemoto
They may always work, but on gentle breaking you'll get pulsing through your hand. And, it'll probably need a heavier grip to pull up in an emergency.
Who knows, not sure of the material, but all sorts could happen to the disk in an emergency.
Replace it.
I had warped disks on an old ZZR a while back and it wasn't very nice the pulsing through your hand when feathering the brake.
John
Honda Transalp XL650
BMW R65
First Honda CB200 in 1978
Biggest Honda CB750F2 in 1981
Lots in between
Despite a long history of doing exactly the same thing, I rode off with my disc lock, yet again, last year and majorly twisted the disc on my Ural.
This was a Brembo floating disc, ie a steel disc mounted onto an aluminium carrier. the result was that it was the aluminium that bent, and I was able to have it pressed back by a bike shop.
If its a carrier-mounted disc and if it's that carrier that got bent, you may be able to fix it...
OK, you may have thought of this idea too.
I don't know how warped your disk is, or how thick it is, ie how much meat there is to play with. However, it may be possible that a machine shop ( with a large enough lathe) could skim it and get the two surfaces parallel again. Obviously, there is a minimum thickness required, That will depend on how much damage is done. Also, this will shorten the life of the disk. In the long term it may not be worth it. In the short term, it would get you on the road for less.
Also, you mentioned in another thread that you (may) have a front wheel.
Quote:
Originally Posted by Titch
Hi there again mate,
One further option for you is... As I'm changing my wheels I will have a spare front wheel, with a fairly new disk attached, and front tyre with approx 2-3 mm tread left on it. But firstly, dont get your hopes up for this too much, as first dibs on this wheel have gone to Warthog, but if he doesn't need it anymore than it could be yours (and also the fact that it is still on my bike at the minute, as funds ran out for me to buy a AT disk for the Dommie wheel...).
Titch.
A wheel that bolts straight on would be perfect. How much are you selling it for?
Is there any way of finding out if Warthog is interested in the near future? I’m getting a bit jumpy now with days left before the MoT runs out.
My nobile is 07989232629 if you want to txt/call.
Thanks again
Email Nick at sales@allbikeengineering.co.uk they Specialize in discs if it can be repaired they will know
