Results 1 to 3 of 3
Thread: Engine painting or not
    shack's Avatar
    Jun 2007
    Devon knows why I'm so creamy
    Hi all, I've got a flakey engine (inside and out) and was wondering about folks experience of removing poor paintjobs on engines, my new (to me) XL600R has had a good splodge (or several) of black stuff over its 28 year life and some parts are back to the metal (and look a lot better for it)
    What are my best (budget) options.
    Removing the engine isn't my fist choice, but may well end up being the case if my rattle won't go away! if that helps.
    Ta muchly Shack
    jasonbc's Avatar
    Camborne, Cornwall
    Re: Engine painting or not
    Quote Originally Posted by shack View Post
    Ta muchly Shack
    This is a local firm to me who do a very good job (see there photo's) which certainly would do the job you want, on the down side you would have to remove the engine from the frame
    Blast Clean and Coatings Limited#
    GASGAS TXT250 PRO 2006
    I would only bother if the engine was being removed from the frame in the case of applying powder coating.
  1. Painting engine cases
    By smallfordsuk in forum Africa Twin
    Last Post: 28-08-10, 09:39 PM
  2. engine painting
    By sean in forum Mechanical Advice
    Last Post: 23-06-09, 01:11 PM
  3. Engine painting. Advice needed.
    Last Post: 30-12-08, 09:05 PM
  4. Painting & engine question
    By Santiago in forum Africa Twin
    Last Post: 01-05-08, 12:00 PM
  5. Painting engine cases
    Last Post: 29-08-06, 11:16 PM
