I have some MM panniers that I may need to fit to another bike. Does anyone know if the loop dimensions and the size of tubing is the same for TT and MM.
The MM method of pannier attachment can cope with only small variances in size.
Quote from the MM web site: "Constructed using 18mm mild-steel tube which has 2mm wall thickness."
and a quote from the TT website: Robust steel pannier frame made from 18 mm diameter steel tube with a 2 mm thick wall. Black plastic coated. env. 53 cm width". I don't know what that last bit means.
