Results 1 to 6 of 6
Thread: What size Renthal Grips for Dakar bars???
    Grendel's Avatar
    Southampton, Hampshire
    I need to change the grips on my TA which is fitted with wide Renthal Dakar handle bars. I fitted Renthal Soft Grips in the past but they have now warn out (perhaps too soft for all year riding) and I can’t remember what size I need to buy 120mm or 125mm or which diameter???
    Anyone know please??
    My TA 600 Page:
    Southampton Safe house
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    Re: What size Renthal Grips for Dakar bars???
    get a rule out and measure them
    Grendel's Avatar
    Good point.
    I just guest last time and they where a pig to get on so wandered if I had the wrong size originally.
    My TA 600 Page:
    jasonbc's Avatar
    Camborne, Cornwall
    Quote Originally Posted by Grendel View Post
    Good point.
    Easiest way to fit is spray the handlebars with carpet glue and the inside of the grip with th ecarpect glue, puncture the end of the grip where th ebar end should go and slide it on. If you don't puncture the end of the grip it will fire itself back off again
    GASGAS TXT250 PRO 2006
    Grendel's Avatar
    Thats the problems i was having last time ended up turning the soft grips inside out to put them on.
    My TA 600 Page:
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    Good point.
    LOL i wasnt being a smart arse, sometimes measuring is the only way to tell. if they were hard to get on before, thats a good thing. if they were the wrong size, ie you were trying to get 7/8" grips on 1" bars, you'd never have done it.(i hope you would notice if you were trying to put 1" grips on 7/8" bars? lol). i believe, although i could be wrong, that all renthal bars are 7/8", including the fatbar range that are waisted down to 7/8" at the ends.
    as for the length, put on whichever length you want and move your switchgear to suit, but sometimes its a juggle if youve got handguards on there too.
    i use hairspray (the wifes, i assure you) use an old fashioned aerosol type with solvent in, that pump bottle stuff is rubbish. the grip slides on, the solvent dries and the grips stuck on, easy. if youve got heated grips i would use the proper grip glue, can get it from dealers. i dont know about the hole in the end, renthal bars are straight through so air escapes easily
  1. Renthal Bars
    By cabbage2404 in forum Africa Twin
    Last Post: 11-02-10, 10:28 AM
  2. For Sale: mint Renthal Dakar and used stock bars
    By scarfacehugo in forum For Sale / Wanted
    Last Post: 13-10-09, 12:25 AM
  3. Renthal dakar high handlebars question
    Last Post: 04-12-07, 08:26 PM
  4. Renthal Dakar High bars vs Standard AT bars
    By lootch67 in forum Africa Twin
    Last Post: 08-01-07, 11:46 PM
  5. which renthal bars
    By harrisphil in forum Transalp
    Last Post: 28-11-06, 03:51 PM
