Re: honda mtx 125 starting problems
Your best bet is going to be to track down a wiring diagram.
This is for early models...
CDI Connections:
2-Pin connector:
Black/Red - coil in alternator
Black/White - Kill and Ignition (kills ignition when earthed)
4-Pin connector:
Green - Earth
Blue/Yellow - Pulse Generator
Green/White - Pulse Generator
Black/Yellow - To Coil
Coil Connections:
Black/Yellow - from CDI
Green - Earth
So, the Red/Black wire from the alternator goes to the CDI unit. The Black/Yellow wire from the CDI goes to the coil. If you've connected the alternator to the coil, it won't work 'cos you've bypassed the CDI.
