xl600r how do i set float level?
Results 1 to 6 of 6
Thread: xl600r how do i set float level?
    purepower is offline Member
    Jul 2011
    england
    hi guys, this might sound a stupid qestion to some of you, but how do i set the float level on my 84 xl600r? the overflow/drain screws are in as tight as i can get them, but the overflow tubes/breather pipes still dribble a little amount of petrol when the engine is running, this tells me the float level is incorrect, [which could be part of my bog, or reving high when throttle released?] my manual dosent realy explain the procedure too good, it says...[adjust the float level by carefully bending the float arm until the float tip just contacts the float valve] [float level 18mm] there is no diagram or nothing else, i dont have a clue as ive never had to do this before, which part is the float arm? which part is the float tip? i now which is the float valve, but from [where] to [where] do i measure 18mm? and can i do this with them on the bike? if someone could help me how to do this [talk me through step by step] you will be greatly appreciated hope someone can help, thanks in advance
    Boris's Avatar
    Boris is online now Wrinkled member
    Oct 2006
    Edinburgh, Scotland
    Re: xl600r how do i set float level?
    Quote Originally Posted by purepower View Post
    More than likely a piece of grit or such in the float valve assembly as the float would have to be miles out for fuel to reach the overflow. Strip it and give it a good clean and blow through with compressed air.
    I'm on the Safe House List
    tendays's Avatar
    tendays is offline Senior Member
    Jun 2006
    birmingham uk
    or could be a crusty o-ring on the float needle?
    /td
    dl650k7
    drz400sk5
    Boris's Avatar
    Oct 2006
    Edinburgh, Scotland
    Quote Originally Posted by tendays View Post
    I don't think there will be an o-ring in the float valve. Usually the end of the float valve itself is soft rubber and that seals against a drilling in the body of the carb. It's also spring loaded so check the spring moves freely.
    Float hight is measured from the gasket face of the carb to the top of the float with the valve shut BUT NOT COMPRESSING THE SPRING IN THE FLOAT VALVE so lay the carb on its side so the float lightly rests on the valve and closes it without compressing the spring in the valve.
    As I say more likely to be muck or if you are unlucky a damaged pointy tip on the float valve. Rotating the valve through 180 degrees may make things better.... or worse, but if it's damaged a replacement valve is the only long term solution.
    Boris's Avatar
    Oct 2006
    Edinburgh, Scotland
    Quote Originally Posted by Boris View Post
    Actually there is a good write up with picture here
    http://site.getmyip.com:8000/motorcy...ing/index.html
    Jul 2011
    england
    boris, that was exactly what i needed, pics and everything, soooooooo mutch help, ive been stressing and now feel good will take carbs off tomorrow and do all what ive just read, will let you now how i get on tomorrow, thanks boris, realy realy realy apreciate your time and help
  1. Honda CR125M Float bowl nos
    By Admin in forum eBay - CR/CRF/CRM
    Last Post: 20-01-11, 07:30 PM
  2. Replies: 14
    Last Post: 22-01-10, 05:06 PM
  3. Float level height
    By Mutley in forum Transalp
    Last Post: 27-06-06, 05:20 PM
