Results 1 to 8 of 8
Thread: Voltage
    pdsquire's Avatar
    Sep 2008
    Surrair
    Voltage
    I really, REALLY don't understand electricity. The car has a voltmeter that is showing about 11V when the car is running.
    Putting the multi-meter across the battery terminals shows 12.10 at rest and 11.30 when running.
    Can there be any other explanation than that the alternator's shot?
    Thank you in advance,
    Philip
    Re: Voltage
    Sometimes it can be as simple as an earth strap broken somewhere. I had a non charging battery on a 2001 Ford diesel and that's all that was.
    AlanH's Avatar
    Bristol, UK
    Re: Voltage
    Quote Originally Posted by pdsquire View Post
    Is it French or a Jag?
    Windmill John's Avatar
    Oct 2008
    Re: Voltage
    £435 for the whole car and you're whinging about a volt! Should have stuck with the Matiz
    Honda Transalp XL650
    BMW R65
    First Honda CB200 in 1978
    Biggest Honda CB750F2 in 1981
    Lots in between
    AlanH's Avatar
    Bristol, UK
    Re: Voltage
    Even a broken Jag is nicer than a Matiz. The seats are comfy and you can pretend you're a film villain of some sort or a copper on a stake-out In a Matiz, even a working one, you'll just look slightly sad.
    pdsquire's Avatar
    Sep 2008
    Surrair
    Re: Voltage
    Give over with the Matiz! They're great!
    Tis a Jag, Alan.
    AlanH's Avatar
    Bristol, UK
    Re: Voltage
    They're great.
    Oh no they're not...
    francis_geoff's Avatar
    francis_geoff is offline Chief Lurker
    May 2005
    Southampton
    Re: Voltage
    Philip
    If the volts go down when engine is running, either the battery is u/s, the alternator is u/s or both are knackered!
    Try a battery off another car - if the same thing happens - the alternator needs looking at - the alternator will probably be repairable - there are loads of repair workshops in S London.
    I assume the red light is working on the dash and is going off?
  1. cdi voltage
    By ade in forum XL
    Last Post: 23-03-11, 10:42 PM
  2. Honda xlr 600 voltage regulator
    By Admin in forum eBay - XLR
    Last Post: 20-01-11, 09:10 AM
  3. Voltage
    By Slaphead in forum Africa Twin
    Last Post: 02-12-08, 10:23 PM
  4. XRV Voltage regulator
    By Sparky1969 in forum Africa Twin
    Last Post: 12-09-06, 10:12 AM
  5. Voltage meter
    By jabba in forum Africa Twin
    Last Post: 31-01-05, 08:48 AM
