Hi, My throttle cable is beginning to stiffen up.
What is the best lube to put in it?
Rick
Rick
GASGAS TXT250 PRO 2006
youll need to buy a cable oiler aswell
here`s an old timer factory racing trick for a super slick throttle ,,,,,,,,,,,,,,,
remove said throttle tube , and get it bone dry and free from oils n grease etc etc , same for the handlebar last 4 inches
put some talk down the tube , and on the end of the handle bar ,,,,,,,,,,,,,, yes , i said talk !!!!!!
try it you`ll be amazed at the difference
as used by all the top race teams ,,,,,,,,,,,,,,,
A light oil like wd40 squirted down with a syringe while working the cable works for me
'02 Transalp
'01 Transalp (Transrat)
'98 Transalp
'91 NC30
'08 Hornet (Vanessa's)
I use 3 in 1 for cables, yes, I said 3 in 1
I find it a bit like a watch maker's oil, quite thin and hopefully not prone to damage linings etc.
Honda Transalp XL650
BMW R65
First Honda CB200 in 1978
Biggest Honda CB750F2 in 1981
Lots in between
Whatever they speak in Greece.
I use an oiler similar to this; Motorcycle Throttle Brake Cable Lubricator Oiler Tool | eBay . . . . . . with a silicone spray, . . . Teflon like jason uses may be even better.
just spray till it comes out of other end of the cable.
Or you could just give it a good 'talking' to.![]()
ah yes talk lubrication...
please dont google "talk lubricants"i did........
i've always used oil for my scotoiler in my cables seems to hang about for a long time and never had a problem or needed to re-oil.
The love of one's country is a splendid thing. But why should love stop at the border. Pablo Casals
