Originally Posted by
alff
Thanks.
Bloody confusing things. I think I pretty much have it simplified down now though. When I press the electric start the ignition coil changes the volts from 12 to many thousands, the ignition control module controls their timing so the spark plugs fire at the right time. Igniting the mixture, starting the engine. Then when the engine is running the ignition coil continues changing the 12 volts into thousands, ignition control module releases them at the correct time, engine keeps running.
Unconnected to that the stator is generating power, rectifier converts it, power feeds the battery, battery feeds the ignition coil. Cycle continues.
Is that correct or is the process different when the engine is first starting?
Thanks again.
