cleaning a float bowl
Results 1 to 10 of 10
Thread: cleaning a float bowl
    shack's Avatar
    Jun 2007
    Devon knows why I'm so creamy
    Hi All, I'm just stripping and cleaning my carbs (XJ750) and I have an amount of stubborn sediment in the bottom of the bowl, I've attacked it with carb cleaner and will shift with a tentative prod with a screwdriver, but what is a cheap, easy way to clean it out. It's been off the road for 12 years so fairly dried on!
    Ta muchly
    More Bill Oddy than Ray Mears
    1990-2000: CG125, RXS100, GS500E, XJ600, XL600V,
    2000-2010: GSF600, NX650, F650GSPD, XRV750, XJ600, XTZ 660 (Tena-lady),
    2010- XL 600V (Lola) & XL 600R (Buggy), T400 (Toni), CCM 604 E (The Banana)
    TT250R (The Bimbler), K100RS (Buwger) & XJ 750 (Sonja), DRZ 400S (Dizzy) F650GS (Jaffa) but for how long?
    We are all in the gutter, but some of us are looking at the stars
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: cleaning a float bowl
    I have been told cheap coca cola, boil em in washing powder, ( makes awful stink buy cheap camping stove and do it in garage, ) or get someone with ultrasonic cleaner to zap em , if no one closer I have one you could bring em over
    visit www.japfest.net for The classic Jap Bike show at Haynes Sept 15 2013<br>
    AlanH's Avatar
    Bristol, UK
    Dishwasher - but don't let SWMBO find 'em in there.
    KTM 990 Adventure
    Windmill John's Avatar
    Oct 2008
    Or just scrape it or ignore it. It is pretty well bonded, so shouldn't affect you...unless it is sooooo much it affects the quantity of fuel.
    http://www.windmillhillvillage.co.uk
    Off road in Portugal; Cracking Grommet
    First Honda CB200 in 1978
    Biggest Honda CB750F2 in 1981
    Lots in between
    thetimkirby is offline Senior Member
    Dec 2008
    anglesey
    Have you got a compressor? There are a couple of threads about soda cleaning, with impressive results for little money. Especially suited to delicate or intricate stuff, as the cleaner is quite soft and is water soluble. Carbs look brand new afterwards.
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    Hmmm, if it's been stood for 12 years the carbs probably want stripping & ultrasonically cleaning if they weren't drained......
    Have you had the bike running?
    '02 - 650 Transalp
    '92 - VFR750
    '91 - NC30
    (UK spec)
    '08 - 600 Hornet for sale
    (kind of....)
    shack's Avatar
    Jun 2007
    Hi Phil (and thanks all) I was mid strip when started to discover the crud, PO put some fresh fuel in and said it rathan for a minute a few months ago, but can't varify this, I was suspecting this one to be a little bad as no fuel came out when I tried to drain it, where as other 3 were fine (easy to drain but yet to take them apart!) I'll whisk it into the kitchen later and try some of the home made remedies (someone needs to be out first) I'll keep you posted, also on a sep note roughly how much oil would you recommend dropping into the plug sockets (as in ml not l! as have read if not run for a while then drop a bit to lube it up a bit and turn over by hand, but a bit in my book could be anythinng from 5ml to 40ml!) I'll chuck a piccucture of the offending article when I get a minute
    hotbulb's Avatar
    May 2009
    Cardiff
    Others may suggest differently, but on these occasions I usually put about 5-10ml (couple of teaspoonfuls) of oil in each cylinder. A thin oil is fine, and as I have it available, I tend to use Redex rather than 3-in-1 or engine oil (allegedly its additives do a good job of softening crud, as well as lubricating). Leave it for a while to penetrate, and don't forget to stuff the plugholes with rag before you turn the engine over! I was amazed how far an old Land Rover engine could spray Redex from its plugholes when turning over on the starter, even with a flat battery.
    Last edited by hotbulb; 21-05-12 at 10:38 AM. Reason: Spelling! ... I blame my sticky keyboard.
  10. The Following User Says Thank You to hotbulb For This Useful Post:
    shack (21-05-12)
  11. #9
    Boris's Avatar
    Oct 2006
    Edinburgh, Scotland
    Quote Originally Posted by shack View Post
    I hadn't realised you take the bike onstage with you.
    Is it part of your act?
    I'm on the Safe House List
  12. #10
    shack's Avatar
    Jun 2007
    All good info, and will have to dig out my old redex!
    Why the Sticky Keyboard
  1. xl600r how do i set float level?
    By purepower in forum Mechanical Advice
    Last Post: 26-01-12, 10:42 PM
  2. Wanted: landrover series lift pump glass bowl
    By R0vers in forum For Sale / Wanted
    Last Post: 08-11-11, 09:33 PM
  3. Honda CR125M Float bowl nos
    By Admin in forum eBay - CR/CRF/CRM
    Last Post: 20-01-11, 07:30 PM
  4. Honda crf 250 power bowl
    Last Post: 10-01-11, 10:50 PM
  5. Float level height
    By Mutley in forum Transalp
    Last Post: 27-06-06, 05:20 PM
