Facet Fuel Pump - Page 12
Page 12 of 12 FirstFirst ... 2 10 11 12
Results 111 to 115 of 115
Thread: Facet Fuel Pump
  1. #111
    Chad's Avatar
    ESSEX RIVIERA !
    Quote Originally Posted by GSPD750
    I've attached a pic again which you can expand. As you can see the slots that push into the mounts on the frame are not totally 'sqaure' to the pump. That is why you have to slightly bend the supports on the frame before you will be able to slide it on.
    dude you've got the worlds first GIMP fuel pump
    but mine likes the look so im going to give it a go
    Chad's Avatar
    ESSEX RIVIERA !
    meet gimp fuel pump no 2
    all fitted now and running smoothly
    wow that rubber was tight my metod was to heat it up with a fan heaters smooth some tallow round the inside then apply the BFI method
    thanks for all the tips it made life a lot easier
  4. #113
    lootch67's Avatar
    South Ockendon, Essex
    Mine went on very easily - it helps if you've got an extra pair of hand though.
    '98 Black AT, Motad Crash Bars, Baglux Tank Cover, MRA Variable Screen, Centre Stand, GIVI Topbox, Renthal bars, Touratech Handlebar risers, Heated grips, 12V socket, IMS Pegs
    Dropped = 3
    '02 KLR650 AT Handlebars??! & lots of plans.
    Dropped = 2
  5. #114
    GSPD750's Avatar
    Calgary, Alberta Canada
    Quote Originally Posted by Chad
  6. #115
    Chad's Avatar
    ESSEX RIVIERA !
  1. Facet fuel pump installation...long
    By GSPD750 in forum Mechanical Advice
    Last Post: 23-07-12, 04:24 PM
  2. Replies: 12
    Last Post: 01-01-07, 10:07 PM
  3. Facet Fuel Pump, Clicky?
    By mgillespie in forum Africa Twin
    Last Post: 13-11-06, 08:35 PM
  4. Facet fuel pump installation...long
    By GSPD750 in forum Africa Twin
    Last Post: 01-01-70, 11:59 AM
  5. Facet Fuel Pump
    By DaveS in forum Africa Twin
    Last Post: 01-01-70, 07:27 AM
