Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: 1150GS Clutch
    DaveS's Avatar
    DaveS is online now Ex XRV Site Owner
    Nov 2003
    Bristol, UK.
    1150GS Clutch
    I think my clutch is very slightly slipping.
    I've read that the GS's clutches can be made of chocolate, so I'm wondering if its on its way out.
    It's only done 13K miles... perhaps I'm just being slightly paranoid though. It still holds well but seems to be slippy when disengaging it. As its hydraulic there's no adjustment.
    Is there a chance that the fluid (3 years old) could be creating the problem?
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    Sharribee's Avatar
    Sharribee is online now Matron
    Jan 2006
    Wales
    Re: 1150GS Clutch
    Dave, Jason said that it could be as fluid goes hydroscopic (no idea what it means) He also said that his does it right at the end of the travel and had been wondering if his was starting to slip. He suggests asking the GS technical forum or wait for the lovely Tarka who knows lots.
    cough shouldhaveboughtahonda cough cough
    DELILAH
    2010 F800 GS
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Re: 1150GS Clutch
    Quote Originally Posted by Mabel View Post
    Yes I wondered when I was going to get that post.
    I'll perhaps try the fluid change to see if it makes any difference.
    2010 KTM 450 EXC-R
    Rubberchicken's Avatar
    Amsterdam
    Re: 1150GS Clutch
    Do you mean hygroscopic?
    That means it attracts water. Which boils and turns to gas when you compress it, and water vapour compresses really well.
    Dot4 brake fluid does this, clutches use the same stuff I guess. That's why you should always use a fresh sealed container when replacing the brake fluid, and not some old opened container left over from the last time you changed the fluid.
    If you've never changed the fluids in 3 years, then it's about time.
    Michel
    '89 NX650 -- R.I.P. -- Gone
    Re: 1150GS Clutch
    Quote Originally Posted by DaveS View Post
    Just run new fluid through it, it's probably full of dirt, water and air. Just keep bleeding it till only new fluid comes out, rather than emptying then trying to refill it. My FJs got a bit temperamental if the clutch fluid wasn't changed every 18 months or so.
    Tarka's Avatar
    Sep 2006
    Wirral, England.
    Re: 1150GS Clutch
    I luuurve that gurl
    Being inferior to the vastly superior 1100 ( ahem ) the 1150 is known to have a few hydraulic clutch actuation related problems....follow the advice posted about the fluid and also check the mechanism piston/seal.
    There`s been lots of posts on UKGSer about it...try a Forum search or two.
    Sharribee's Avatar
    Jan 2006
    Wales
    Re: 1150GS Clutch
    I've no idea what it is supoosed to be but Mr Mabel did mention something about it attracting water so maybe, I just did the typing
    DELILAH
    2010 F800 GS
    Simon Guest
    Re: 1150GS Clutch
    Should it not be;
    shoudn'thavesoldahonda
    Mabels Old Man's Avatar
    May 2006
    The Dark Side
    Re: 1150GS Clutch
    Which of course have totally indestructable clutches which never wear out
    Oh bugger I bit
    1995 Fireblade Urban Tiger
    2009 BMW R1200GSA
    Events Manager GS Club
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    Re: 1150GS Clutch
    Dave it is highly unlike that the clutch is knackered at 13k miles. Change the fluid and check it again.
  1. Clutch (less)
    Last Post: 29-08-06, 11:08 PM
  2. Clutch Differences
    By Richard in forum Africa Twin
    Last Post: 22-04-06, 04:52 PM
  3. Clutch basket
    By ChrisH in forum Transalp
    Last Post: 26-08-05, 08:56 PM
  4. 1150GS
    Last Post: 21-08-05, 09:26 PM
  5. Clutch tic tic tic
    Last Post: 06-05-05, 12:08 PM
