Results 1 to 5 of 5
Thread: MTX 125 RW-L Problems
    frazer1981 is offline Junior Member
    Jan 2008
    northants uk
    HI there.
    I am new here and have a few questions to ask regarding my 1992 mtx 125 RW-L and hoefully somebody can answer them or point me in the right direction.
    Fristly when i ride the bike it does not sound like it is running right in 1st and 2nd gear but once into 3rd it runs fine and goes like a dream. Having owned a mtx 125 in the past i never had any problems with this and don't know where to start. The engine has been totally rebuilt and ran in but was then stored for a year untill i bought it. I took the cylinder head and cylinder to check for worn piston but this is fine, but it feels like it is hesitating or missing or something as i am un sure.
    Also does anybody know of any good places to infomation on the bike such as specs and also spares parts?
    Hopefully somebody can help me out as my local motorcycle dealer isn't honda and the only advice i have had from them is that i should'nt have bought a honda??
    Thanks in advance.
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Re: MTX 125 RW-L Problems
    You would need to give us more to go on, like did it run fine before it was laid up? Also more info on what happens when you ride it? I reckon the engine would either run ok or not, but it wouldn't be dependant on the gear you were in.
    Off the top of my head, I'd say it's a fuel problem, maybe reed valves tired? Or could just be waxing in the carb but you haven't said if you've checked yet?
    Best of luck mate.
    hondaxrnut is offline Senior Member
    Oct 2008
    somerset
    sounds like your local bike shop is staffed by idiots, should not bought a honda, i seldom buy anything else, what prats, they make more reliable bikes than anyonbe else.
    any way to the problem, check your fuel system, sometimes the old 2 stroke oil can clog the slide, the flaot and jets i had an old pe that was not run for a while and i could not get the throttle slide our for a few days.
    check the electrics, especialy earth wires.
    good luck
    ritosxf's Avatar
    ritosxf is offline sfx wheels
    Jul 2009
    walsall , well cheslyn hay to be exact , jnc11 m6
    a 2stroke only needs afewthings torun
    a spark,,,, at the right time
    compression ,,,,,, ifits done morethan 8000 milesit might need a piston ora rebore
    check out jetbore nr wolverhampton
    and fuel , give them jets a damn good clean,,,,,,
    ritosxf's Avatar
    Jul 2009
    hessitating or slight missing
    try dissconnecting the kill switch, a bit of water in here will cause it to playup,,,,,,
  1. Xr 400 Problems??
    By endurojoe1985 in forum XR
    Last Post: 08-12-07, 05:03 PM
  2. 1st problems
    By Wold Rider in forum Africa Twin
    Last Post: 28-04-07, 11:07 PM
  3. big end problems
    By rikki1q in forum Dominator / FMX
    Last Post: 06-04-07, 12:38 PM
