Results 1 to 7 of 7
Thread: kawasaki advice
    spicy mchaggis's Avatar
    spicy mchaggis is offline Living for the weekend
    Jan 2008
    lyme regis
    Question kawasaki advice
    Hello all, i've been looking around for a bike for a while, and came across one locally, a Kawasaki KLR 650 Tengai. It seems in alright condition, just a few scratches and scuffs.
    if anybody has owned one of these, or if anyone knows what there like, reliability, reputation, classic 'bad traits' or genral advice about it, it would be a great help.
    cheers, will
    barftone's Avatar
    barftone is online now Senior Member
    Apr 2005
    Bath, England
    Re: kawasaki advice
    If it has had regular oil changes they are pretty reliable. Handle well if the rear shock is not knackered. The finish is pretty poor by Honda standards. Loads in the States so take a nose around ADV rider forum and see what you can find.
    Jan 2008
    lyme regis
    Re: kawasaki advice
    Yeah, i quite like the look of the bike, so hopefully there shouldn't be too much wrong with it.
    ill have a gander at adv, see what they've got to say, cheers.
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Re: kawasaki advice
    I had a 1990 one a few years ago now, it was a couple of years old. I can't really fault the bike that much, well, apart from it's a Kawasaki!
    Being a thumper single I found I was constantly paranoid about the bottom end of the engine, although they're more prone to running the top end!
    I bought an @T to replace the Tengai and never looked back, smoother engine, more power and better build quality.
    I suppose someone has to buy Kawasaki's, it just won't be me!
    Just my opinion, before I get flamed!
    Jan 2008
    lyme regis
    Re: kawasaki advice
    yeah, i would prefer a honda (the one in the pic is my dads) but im skint, and i wanna get something cheap. i only passed my test the other day, and im eager !!, wanna get as much riding in as i can, so when i leave school i can have a proper summer
    the kawasaki should be alright, just needs a new speedo in mph, and a bit of a genral service and clean up.
    maybe a AT for my gap year.
    The Pheasant is offline Senior Member
    Surrey
    Re: kawasaki advice
    africajim is right about the KLR's top end. I had a 600 bought new which was 100percent mechanically (but not electrically) reliable including a 2-up tour to Italy and plenty of trail riding. However, the wet sump is shallow and, if one of these bikes is wheelied, the oil can drain away from the pump pickup, leaving the cam bearings to run dry.
    The other problem is with the chain-driven double balancer shafts, one of which drives the water pump. The tensioner sticks. If the chain gets slack the mechanism can break.
    The 650 and Tengai - both have the same motor - came later but because they have essentially the same architecture as the 600 are prone to the same problems. There is lots of info on the Tengai and 650 lump here: http://www.bigcee.com/klr650faq.html.
    Provided your Tengai has neither major problem it should be good.
    Jan 2008
    lyme regis
    Re: kawasaki advice
    cheers pheasant, that link is a great help
  1. Kawasaki Thingy .........
    By Wee Jack in forum Other Bikes
    Last Post: 30-07-07, 10:37 PM
