Results 1 to 2 of 2
Thread: C.T.110 rear brake hub .
    tastaka is offline Junior Member
    Nov 2009
    Dunedin N.Z.
    can any one help?
    we have a 1992 C.T.110 rear hub that is worn break pedal just grips drum . we need to know what the diameter of the break drum should be along with the wear limit max, ex postie done 60,000 k.m.
    advise much appreciated. thanks.
    Lumiya's Avatar
    Ziost
    Re: C.T.110 rear brake hub .
    Hi Tastaka and welcome to the forum.
    You posted this message in the "problems with the forum" section that is reserved for people who are having problems with the site and not problems with bikes So I've moved it to a more correct area and where people are more likely to see it I hope you find the answer you're looking for.
  1. SLR650 rear brake pad pin
    By captainmish in forum Dominator / FMX
    Last Post: 18-08-09, 08:21 PM
  2. Rear Brake
    By AncientAndy in forum Varadero
    Last Post: 15-04-09, 10:22 AM
  3. Brake light delayed from rear brake pedal
    By slanty in forum Africa Twin
    Last Post: 05-06-08, 10:32 AM
  4. Rear Brake !
    By fatowl in forum Transalp
    Last Post: 16-04-08, 02:49 PM
  5. Rear Brake Callipers
    By treehugger in forum Africa Twin
    Last Post: 27-10-05, 01:08 PM
