Hi guys, MOM is having problems posting in the calender, any ideas????
xxx
xxx
DELILAH
2010 F800 GS
No problems posting and then deleting a test event. Does he get any error messages?Originally Posted by Mabel
Kymmy
I have had no problems either, he does get an error message but he can't remember what. (must be his age)
He is going to try again and then post here the message he gets
Thanks Kymmy
DELILAH
2010 F800 GS
OK tried again and I get the following
Arse! Query failed:
errorno=1064
error=You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's Old Man', 'I\'ll be there ')' at line 9
clean_query=INSERT INTO tbl_event_participant (fld_event_id, fld_participant_user_id, fld_participant_username, fld_participant_comment) VALUES (128, 1141, 'Mabel's Old Man', 'I\'ll be there ')
Hope this means something to somebody
By the look of it the words I'll be there is throwing up the error. Try altering that line to something else especially without the apostraphyOriginally Posted by Mabel's Old Man
Kymmy![]()
Okey dokey Tried something simple with no punctuation
Arse! Query failed:
errorno=1064
error=You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's Old Man', 'My calendar is clear')' at line 9
clean_query=INSERT INTO tbl_event_participant (fld_event_id, fld_participant_user_id, fld_participant_username, fld_participant_comment) VALUES (128, 1141, 'Mabel's Old Man', 'My calendar is clear')
See told you it doesn't like BMW riders.
Nope, only thing I can think of is that it's the apostraphy in your usernameOriginally Posted by Mabel's Old Man
The code is trying to seperate inputed text and code by the use of apostraphies, you having one in your username is getting it confused. Try going into your profile and changing the username then retrying the entry...just remember you might have to login again using the new username and password
ThanX Kymmy![]()
I'd agree with that - apostrophes cause merry hell in MS SQL anyway, if not doubled-up![]()
This can be sorted in the php code..... it is the apostrophe that's causing the problems.
Leave it with me a bit to sort.
Forum help and advice needed?
2010 KTM 450 EXC-R
Follow xrv.org.uk on Twitter.
OK bossOriginally Posted by DaveS
