Results 1 to 10 of 33
Thread: [MERGED] Can't load photos
    pdsquire's Avatar
    Sep 2008
    Surrair
    I've not had the problem before, but this morning, after the photos are loaded from my camera and after I have been asked for the titles, the next screen refuses to load so the previous 10 minutes is wasted. It's happened three times and I am not inclined to try again.
    Images are 3.3MB (is that right) from a standard digital camera.
    Ta!
    Philip
    Lumiya's Avatar
    Ziost
    Re: Can't load photos
    Quote Originally Posted by pdsquire View Post
    Images are whatever size the camera does, there's no such thing as standard. Even if we knew theMP rating of the camera it also depends on if they're in fine/economy mode and also what JPG compresssion the camera uses..
    can you email one of the pictures and I'll give it a go to the admin address for the website
    Lumiya's Avatar
    Ziost
    This problem is being looked at. No ETA yet for a fix but we'll keep peple updated via this thread.
    I have always had this problem with 10 MP pictures.
    Frad's Avatar
    Frad is offline Senior Member
    May 2008
    Cheshire
    Dont know if mine is the same problem but I have set up a new album but then cannot load photos into that album ?
    It used to say ADD PHOTOS at the bottom but dosn't anymore
    Is that similar to PDsquires ?
    Thanks for your help in advance
    XL 1000 VA '09 In Burnt Orange Honda Top Box, Main stand, Scottoiler, grips, ARDcases.
    XL650 '06 In Black sold
    Elizabeth Kubler-Ross: Quotes: Adventure
    It is only when we truly know and understand that we have a limited time on earth and that we have no way of knowing when our time is up that we will begin to live each day to the fullest, as if it were the only one we had.
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Quote Originally Posted by Frad View Post
    No you're lucky enough to have a different problem! You're using the vB built in way of uploading photo's. Sorry it's all very confusing.
    Will try to look in to yours at some point... or someone will.
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    Frad's Avatar
    May 2008
    Cheshire
    Quote Originally Posted by DaveS View Post
    Thanks Dave
    chalky4's Avatar
    Nov 2008
    Newport Pagnell
    Try opening the photos in a program like photoshop or similar, go into image on the tool bar and re-size image. Save the re sized image (under a different name if you want to keep the original) It will then show you a screen named jpeg options, this gives you the chance to change the image quality. If you reduce this to medium you should be able to post.
    I'm no expert and there is probably a far quicker way of doing it but it works ok for me and my 10mp camera. Hope this helps
    Quote Originally Posted by chalky4 View Post
    That is what I have been doing, plus using another host such as Flickr or Image Shack
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    The problem with the forum software is not a size issue, I've tested large uploads that have worked fine and I have tested small uploads that have failed.
    There is something with the way that Photopost works or is configured that is causing a problem.
    2010 KTM 450 EXC-R
  1. Boot load !!!
    By boboneleg in forum Chatter
    Last Post: 09-01-08, 09:22 PM
  2. load lugging
    By cbcommuter in forum Chatter
    Last Post: 20-01-07, 08:13 PM
  3. Wide load
    Last Post: 16-12-04, 08:20 AM
  • You may post new threads
  • You may post replies
  • You may post attachments
