http://store.ricorshocks.com/
I received the shock inserts, securely packaged in a block of foam and with easy to understand fitting instructions. I removed the front wheel and forks myself, but left the fitting of the inserts to Steve at Silverex Engineering in Braintree, the same man who did such a great job stripping my engine and fitting a new output shaft bearing 38,000 miles ago. I remembered to loosen the fork caps, after first loosening the top yoke clamps, but with the forks still held securely by the bottom yoke, in order to make removing them later easier for Steve.
I handed over the forks to Silverex, returning to collect them later on that day. Steve had removed the top cap, drained out the old oil and removed both the upper and lower springs. The intiminators were pushed down inside the fork, and then 5W fork oil was filled up to the standard level given in the workshop manual. The original Honda springs were refitted and the caps screwed back on. They charged £30 to fit them. I would’ve attempted it myself, but I remembered the times I have spent trying to get the same oil level in each fork on previous occasions because I’m too tight to buy a syringe type fork oil filler and decide to leave it to the experts.
I collected the forks and took them home to refit. Off the bike, they felt quite softly sprung whilst pushing them up and down on the garage floor. I refitted the forks, then the front wheel. I took the bike off the workshop stand and squeezed the brake lever a few times to get the front brake callipers to close up on the discs. I did a few experimental pushes of the bike to gauge the fork dive and they now felt surprisingly stiff with a lot less dive than previously.
I went and got my jacket and helmet and rode a few circuits of the estate where I live. The forks felt very plush when passing over manhole covers and ripples in the road surface, yet stiffer when braking at junctions. A speed table near my house has ramps edged with granite kerbs which stand proud of the adjacent asphalt. Previously when I rode over this it used to jar my hands through the handlebars (it makes a hell of a jolt when I drive my car over it too). With the intiminators fitted it was like riding a hovercraft over the ramp, no jarring through the bars at all.
Next morning I rode the bike to work, a 100 mile round trip along a dual carriageway and then the M11 south to London, a large 3rd world city if the state of it’s roads are anything to go by. I have been doing this trip on Africa Twins nearly every working day since 1997. That’s about 250,000 miles on the same route. I know every bump, dip and pothole intimately and I intended to try and ride over most of them.
At 80mph on the dual carriageway and motorway the forks seemed to be very relaxed, shrugging off any cats eyes caught when changing lanes. A particularly evil lump in the fast lane of the M11 just after the Harlow exit normally makes the bike leap about a bit. This time I just seemed to float over it. I went up to a 100mph a few times purely for research purposes and the bike seemed less skittish than other times, although that may be because it was a relatively calm day wind wise. Braking caused less dive than previously, something that I will appreciate when riding on unlit roads at night, as my headlights will now hopefully light up the road ahead rather than pointing downward temporarily. When I got to east London I searched out every crappy road surface I could (plenty of choice), the difference was pretty dramatic.
After I finished work I headed back out of east London. There was a big problem with traffic and I had to filter between slow moving cars for about 12 miles. Normally I move from side to side to avoid riding over the cats eyes which set up an annoying hammering if ridden over for any length of time. This time I aimed for them to compare the difference. The forks were handling them brilliantly, my rear shock wasn’t, it’s age and condition really shown up by the new life given to the forks.
Instead of carrying on up the motorway I left it at the Harlow exit and headed across country. This route is one I take on sunny days when I’ve had enough of boring motorways and crowded roads. It’s about 30 miles of narrow winding and occasionally fast roads which I usually have to myself (barring the odd tractor or deer). It also has some of the bumpiest stretches I regularly ride over. On my old RD04 I used to stop as soon as I got off the motorway and let the air out of the forks to soften them prior the hammering I was about to get. It started piddling down as I left the motorway so I stopped to put my waterproofs on.
By the time I set off again the lumps and bumps in the road were showing up by the standing water in them. I was able to ride most of the route at a quicker pace than usual, as the bike wasn’t jumping about so much on the bad sections. Despite the rain I started to enjoy the ride, something that doesn’t happen often when you commute in all weathers.
I have to say the forks are now really good on my bike, despite still having the original fork seals (ya gotta love fork gaiters) and springs which have done 86,000 miles already. As I said earlier, it has made me want to replace the rear shock, as anything the forks shrug off just gets me when the rear wheel goes over it.
The good news for Africa Twin owners is that Ricor are offering the same 50% discount as they were to Transalp owners. That means they are available for $149. Just type the code 'xrv.org' when ordering on their website.
