Jim
Did you fit a new float needle to you troublesome carb? I had to ,and I also cleaned up the seat with a drill gently turned between my fingers, before setting my float height to 1mm below chamber joint , and then checking again with the clear tube with the damn thing running.
Lots of U/S Kwaker quad owners have fitted Honda TRX 300 ( big red )carbs to cure this , weird thing is that Keihin is owned by Honda,but they don't fit that particular carb to their bike/quads , starting to smell a rat?
Funny enough ,my daughters KE125 also has a carb prone to flooding,with the difference between petrol starvation and flooding only a mm or so.
Lee
