Results 1 to 7 of 7
Thread: Playing in the sand pit
    lootch67's Avatar
    South Ockendon, Essex
    Maverick and I finished a quality afternoon spannering on our bikes after which I headed off to go play in a newly discovered disused sand pit. I did invite Maverick but unfortunately he couldn't make it.
    A plastic bike is probably more suited to this terrain but I'm sure the satisfaction of dragging a small bike up those inclines would pale in comparison to dragging the AT up there on worn ContiEscapes. The sand is not very deep (certainly no match for the last sand I rode which was in the Namib desert) but enough to make the front go all wayward if you're not on the gas. And of course I just love wringing the old girl's ear... It had a fair amount of traction too due to it being slightly wet which always helps. What also makes this interesting is that you're quite often riding against a bank/angle when crossing into different tracks which had me rather worried that I might loose the front but some "positive throttle" soon turned this into quite a lot of fun.
    I had two "moments". This first was when I crossed from one track to another and overshot the second track and ended up in some grass. I didn't realise that there was a hump in the grass and the next thing I know the AT's tall screen jumps up and smack me on the chin. Thank goodness I was wearing a full face helmet.
    The second moment happened when I again overshot a track (at some speed) and ended up having to follow the alternative route which goes halfway up the bank before making a sharp turn down (sorry, lowsy way to describe it), but not before losing most of my speed as I desperately looked for an escape route. The problem was that I was in the wrong gear and so had barely enough momentum/power right at the top to get me round the bend before the AT fell a good 3m down the bank.
    A brilliant way to end the long weekend! Here's some photos.
    This is where the second moment happened. The track right below me is the one I had to get up.
    Overview of the play pit. I went up or down most of the tracks. My first moment happened as I crossed from the track on the right in the foreground to follow the one going round the tree. There's quite a slope between the two which you can't see in this picture. I ended just to the right of the tree.
    Some of the tracks. My next goal is to learn to power round these bend in style. I'm still a bit wobbly at the moment.
    Last one. Handsome isn't she?
    That's all folks!
    lowflyer's Avatar
    lowflyer is offline Deer Dodger
    Scottish Highlands
    Re: Playing in the sand pit
    First of all, well done
    The trick, I've found in sand is to position your weight over the front and just give it yahoooo.
    The rear will, ultimately, follow into line.
    In soft sand, I find you have to power into the berm and continue through without lifting off, the complete opposite to a hard surface.
    Just my ramblings, I am sure there will be someone along shortly to say I am talking absolute bolloks, but it works for me
    Hope this helps
    '96 XRV 750 RD07
    DR 350
    Free beers tomorrow !!!
    Well done, nice pictures.
    The nack for powering around the corners is to forget it is there and open the throttle wider to overcome the slide, then once around the turn find a bit of concealment to change your underpants.
    lootch67's Avatar
    I've got this thing about high-sides which makes me rather nervous to open the throttle all the way in a a bend. Gotta practise some more I guess... Do I first start to lean into the bend before opening the throttle?
    stanbloke's Avatar
    stanbloke is offline Happy Bunny!
    Jul 2007
    Milton Keynes by the Sea
    [QUOTE=lootch67;367712]rather worried that I might loose the front but some "positive throttle" soon turned this into quite a lot of fun.
    QUOTE]
    What a great place to practice !!..
    Love the term "Positive Throttle" ..
    lootch67's Avatar
    [quote=stanbloke;367758]
    Quote Originally Posted by lootch67 View Post
    I've heard horror stories of guys blindly applying the mantra "Stand up, look up and OPEN up". Seems that some took the "open up" way too literal and we all know where that's going to get you...
    Mar 2007
    Bridport Dorset
    playing in sandpits is always fun,us blokes will never grow up!
  1. I've been playing in Scotland again...
    By Pussyhorse in forum Ride Reports and Pictures
    Last Post: 26-06-08, 05:07 PM
  2. Nothing,just playing
    By Lord Vader in forum Problems with the forum?
    Last Post: 05-11-07, 05:50 PM
  3. Look what I was playing with yesterday
    By Sharribee in forum Chatter
    Last Post: 05-10-06, 10:19 PM
  4. No one playing
    By simplysie in forum Meet Ups / Rideouts
    Last Post: 07-08-06, 07:15 PM
  5. ive started playing already.!!!
    By Chad in forum Chatter
    Last Post: 23-07-06, 12:17 AM
