In the words of James May "Oh C#ck"! - Page 2
Results 11 to 20 of 27
Thread: In the words of James May "Oh C#ck"!
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Re: In the words of James May "Oh C#ck"!
    Cheers mate, I'll just paint them with Satin black hammerite, as said, it'll probably happen again!
    As for protecting the protectors with pipe lagging? That's like having two spare tv's in case the 1st and 2nd one break down! (Oh no, I'm down to my last ten tv's, what if they start breaking down????) Ha ha!
    Crash bars worked, end of. A bit of paint and we're cooking!
    Oh and a bit of heat and bending for that brake pedal! Not sure what to do with the plastics though, any thoughts on removing scuffs? Not painted bits, the black plastic that connects to the belly pan.
    j's Avatar
    j
    j is offline SHW'MAE BUTT
    Apr 2006
    Woops
    Did you get the finger wagg from Fiona . that's what I normally get
  4. #13
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Ha ha! Not really, she just asked if I was ok, the bike will fix so problem solved! Hopefully I'll feel ok tomorrow, past experience is usually next day sore bits appear!
    Just one of those things, a gravel track, rear slid out, but in correcting it the front washed out as well and that's all she wrote!
    As Confusious said "man with hole in pocket feel cocky all day, man with two holes does not feel too cocky" Should've worn my old trousers! DOH!
  5. #14
    Nickel Arse's Avatar
    Nickel Arse is offline Formally snaphappy
    Mar 2008
    ExPat in Germany
    Glad your OK Jim
    Ref the platics how bad is the damage, normally unpainted plastics have a rough surface which is impossible to repair without it showing, If you want the best finish you can try Sanding the scuffs out or CAREFULLY melting them out, all the raised scuffing will melt and lay flat again but you'll lose the surface and it will shine, so afterwards you could if you wanted treat it with plastic primer and paint it.
  6. #15
    lowflyer's Avatar
    lowflyer is offline Deer Dodger
    Scottish Highlands
    Nice ride out guys, sorry couldn't participate -- damn work , going to be easing off shortly, so hopefully be ok for weekend jollys
    Jim, bad luck mate, still, at least your magnificent body is still intact
    What's the craic with the closed gate you bunch of woosses ??
    Never stopped us before
    Guess who knows the combination setting for the padlock ????
    '96 XRV 750 RD07
    DR 350
    Free beers tomorrow !!!
  7. #16
    Cabby's Avatar
    Cabby is offline SOTGATT
    London/Surrey
    Jim...Back to Black type stuff is the best for scuffed plastic similar to car bumpers.
    Not brilliant close up but good from a short distance.
    I've used a cheap Tesko one but any 'tart up spray' should suffice.
    1992 TA600 Silver/White , Givi Bars, Rails. 1997 DR350,acerbis tank....Ready.
    It's not a mid-life crisis....I dunno what it is.....
    A people that values its privileges above its principles soon loses both. Dwight D. Eisenhower
  8. #17
    Whealie's Avatar
    Whealie is online now Wing Commander
    Lewisham, SE London
    Sorry to hear that Jim. Main thing is you are OK.
  9. #18
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Thanks all, I painted the crashbars with satin hammerite after a good rub down, the plastics I rubbed with fine emery and used the back to black, not too obvious now, then heat treated the brake pedal, it was quite floppy with a bit of heat and bent back no problem!
    The mighty Varadero has recovered!
    I'm ok too, a sore elbow but that's a muscle issue I've had for a month or so, aggravated by lifting the bike, my knee is sore but again, an aggravated old injury by sliding along the ground on it! I'm ok to ride though and plan a few miles tomorrow!
    Bring on the next adventure, Galloway forest park! Yeehaa!
  10. #19
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    An event Horizon somewhere
    Quote Originally Posted by lowflyer View Post
    Tis a new one that's only got a walkers width of path round it - with a 4 ft drop beyond that - not great for getting a hulking great big Vara past
    Looking forward to you getting yer arse out of the driving seat and onto the riding seat
    Quote Originally Posted by africajim View Post
    So, you taking an Acetelene torch with you to Galloway, so's you can straighten out the lever again?
    Steve T
  11. #20
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Nah, I'll just rely on the old CBS again! worked fine yesterday! Ha ha!
    Aye, Lowflyer, all's well mate, be good to see you, been a while now!
    Cheers Cabby, I used the cheap Asdas one!
    Thanks Wheallie, makes a change, me sliding along the road mate!
  1. Replies: 4
    Last Post: 08-02-10, 06:41 AM
  2. Proof that "NOBODY" can resist the "Dark Side"
    Last Post: 02-02-09, 12:11 AM
  3. Replies: 4
    Last Post: 31-01-09, 07:37 PM
  4. Aybody fitted the "Vista" 'Cruise Control' - Throttle Lock?
    By Freerangestormer in forum Varadero
    Last Post: 27-10-08, 06:37 AM
  5. Replies: 10
    Last Post: 09-06-06, 10:38 AM
