Have problemku. Length of rod, who is concurrently and vacuum-operated grease feeding 114 mm. The depth of our capacity approx. 85 mm. Experts, the question is: where do I get no dostaŝie millimeters? Answer below:
Take a hairdryer and help our customers to the bottom of the tank. Because the plastic give inside a pair of atmospheres and fozduha polučem missing 29 mm. Everything is simple
Everything. Collect new skotojler zapravlem oil into it, and at least 6 000 not to think about charging.
The idea is to maintain a chain of cardan shaft
Next is a problem occurs while driving in hot weather is cool RRN (relay voltage). To correct this off against there are several ways:
1. Connect an additional plate-radiator, heat will be faster.
2. Connect the CPU cooler from the computer.
Oh and a third way, which I decided to try is a side-Plastik vpat′ reticle in order to reduce the ingress of air. What to do and how to do the following:
drew a big place. Not-on stickers kurgloe left, oblong to bend.
using soldering vypal piece which I stand
is the bullet hole. Not krasva but still to come.
filed in support
fly road Dynamics deepsteam
take the bevel with a sharp noika.
get here such enhanced detail.
Today I changed a few wires wiring that the mounting lamp pereterlis′ and dashboard due to repeated drops. At the same time replaced kmbriki and izolentu.
again, processed water repellent cut all contacts.
frame mounting lamp dashboard and whole mordočki reinforced by additional spacers, painted by a powder paint and set in place.
On-board computer so call this device. Loud name. It's just three tripmetra (daily mileage) and clock
the headlamp type. Xenon, I won't. Reflectors and lenses are designed for normal galogennu light bulb. Therefore, the benefits of Xenon little, only vypendre and blinding oncoming. I'd rather put the lowest at ARC extra lights fog-light.
See svetorasseivatel′ here on the lens. And he should be on Xenon otraatele.
These are the first that I wrote in
article. Dad accidentally they found someone in the village. Two pieces. New!!!! now I am old ready to gift, they are still very much even anything, I'll set pokrau powder coating and on the arc, instead of the old.
cool
see GOST 72 per year. Stayed with the homes in paper impregnated with solid oil .
and here is another one of my assistant. It helps the home computer
but more often it just sačkuet
Today I took some fasteners with chromium electroplating, chromium anodizing, to be precise, these are:
Thank you Wife of Bila Tserkva, thanks to him! And yet it poanodiroval spokes and collects the wheels which I took after polishing disks and install the new hub bearings. A very smart guy.
fork was disassembled and rinsed with
scheme is simple, unfortunately no adjustment, but I have some defined your driving style and identified oil that is best suited. For me it is a Fork fluid 7 Ipone, I've got it covered and has proven to be the best hand. Over 30 thousand I merged not ChaCha black and oil, which had done a little bit. The fork worked perfectly, for hints.
fixed bushings
Here is a special tool made by cutting "ethnic" aluminium tube, all bushes and gaskets is very pleased to become the Chair. All the work was carried out strictly according to the service manual, which can be downloaded from the site
Honda Africa Twin XRV 650-750 section "Download" button.
out bearings, gland and poanodiroval gaečki
is not for beauty in order to avoid corrosion.
fixed chassis air filter
HA! priborka, almost like new, already with leak-proof glass speedometer
water cut performed special connectors
all bearings and dust were replaced by new ones and parts painted plastic paint. Do as for myself, and grandchildren have)))))
continued saga
here
