Results 1 to 7 of 7
Thread: Test Pic
    gibbo is offline Senior Member
    New Zealand
    Test Pic
    Taken on our way up Col de Bonnette. Saw some Marmots but the buggers were gone by the time the camera was ready.
    Cool. Now I have the picture thing sorted I will do the trip report & pics from our Pyranees / Alps trip in Aug/Sept. Need to sort the pic quality though?
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Quality doesn't look too bad.
    Like the pic so will mark it for the home page selection of pics.
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    New Zealand
    Cheers, there are better ones.
    Quality problem must be my eyes - or the screen.
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    I can see it is a bit pixelated but it'll do.
    If you've got any more then post them up.
    2010 KTM 450 EXC-R
    New Zealand
    The pic was taken at max resolution on a 4mpx digi camera. Resized in photoshop to 800 x 600, then to get it to 50kb had to select "low quality" when saving. Thought that should produce a reasonably good shot. I notice some other pics on the forum are very sharp. Whats the secret?
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Its always a compromise but you should be able to get it sharp.
    Don't select "low quality" try telling Photoshup to save it to 50Kb instead.
    2010 KTM 450 EXC-R
    iswoolley's Avatar
    Jun 2004
    Telford, Shropshire
    I use PhotoShop Elements (because it came with the camera) and the Save for Web... function. However, as I pretend to be a semi-serious photographer I have to process my images first (from a RAW format), which includes 'sharpening' the image. The camera has an anti-aliasing mask in front of the sensor to avoid moire effects and so forth. Sharpening removes the blurring effect this mask has on the image. If you've similar software, you could try playing with sharpening to see if that improves the aethetics of your photos.
    Anyway, back to 'Save for web...', as my camera's sensor has a 3:2 aspect ratio, I resize to 600x400 pixels to avoid cropping, then play with the quality slider until the file size is 50KB.
    Iain
  1. test
    By Chad in forum Chatter
    Last Post: 08-04-06, 01:47 PM
  2. The test
    By Sharribee in forum Chatter
    Last Post: 01-04-06, 06:02 PM
