Re: Engine oil
Originally Posted by
Neil G
Hi all.
Once again I ned to pick the brains of more informed folks than I.
My prehistoric '87 VH Transalp has now covered 46,500 miles with the startings of some cam chain noise - not too bad but just noticeable (is it a big job?). I've been using Silkolene Comp 4 10/40 but was considering switching to a slightly more meaty grade, perhaps 15/50 given that I ride all year with a daily commute of around 35 miles total. I also change the oil & filter every 2000 miles. Any thoughts?
Neil.
Bit early for camchain noise. Are you sure one of your sparkplugs hasn't worked a little loose, the noise is very hard to trace and was responsible for me having my camchains changed at 70,000 miles when I found they were still in good condition. I got mine done at Galea Camchains near Basildon and it cost about £200
