Results 1 to 10 of 11
Thread: Brake light switch
    wheeliebin's Avatar
    N/A
    Brake light switch
    Anyone else struggling with the rear brake light switch ?
    Mines been dogdy since new, Honda even replaced it at the first service. Now it's MOT time (thursday) I'm having trouble getting it to work.
    The switch seems too sensitive to adjust, I can get it working, go for a ride and the brake light will be stuck on, back off the switch a quarter of a turn and the bloody thing won't work again !
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    I know what you mean, they seem very sensitive - it's as if where the spring is attached to the lever doesn't have enough travel and should be mounted further from the pivot point
    I'm sure you will have doused it in WD40 and given it abit of a working. Sorry can't be of more help
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    Carport is offline Senior Member
    Newport
    Mine on the @ is also a tad sensitive.
    WD40 is the way forward.
    Yeti's Avatar
    Yeti is offline Serial Scenic Router
    Jul 2004
    Darlington
    Mine on the TA is also naf!
    Like my scotoiler...on or off!! no adjustment in between
    wheeliebin's Avatar
    N/A
    As Phil says - "If in doubt - Bodge It!"
    There's just not enough movement at the pivot point, and the spring seems too weak.
    Simply put a small cable tie around the spring so it acts as a straight connection now, works a treat
    Leigh (& Saltburn!)
    Never thought of that!
    Y' learnin' fast m'lad :P
    '02 Transalp
    '98 Transalp
    '91 NC30
    wheeliebin's Avatar
    N/A
    She Passed !
    only just though, front discs are a little warped.
    Confucious's Avatar
    Confucious is offline Senior Member
    Norway
    Re: Brake light switch
    Quote Originally Posted by wheeliebin
    I have a Dominator. I depress the brake pedal...the brake light comes on .....little further on the brake pedal...it goes off. As much as to say " I'll make the car behind you slow down before it hits you - that way you'll hopefully still be alive AND get a new bike
    This was one of the jobs I was supposed to do before the snow melts and I can get out again...thanks for reminding me
    Leigh (& Saltburn!)
    She Passed !
    Mines for the MOT this w/end, disks a little warped too (just like it's owner )
    '02 Transalp
    '98 Transalp
    '91 NC30
    Austin's Avatar
    GARSTANG
    mine works just fine. But then I've never ever even looked at the brake switch.
  1. LED Tail/brake light.
    Last Post: 28-03-11, 10:55 PM
  2. Front brake light switch
    By Fentible in forum Africa Twin
    Last Post: 08-08-07, 10:38 AM
  3. Front Brake Light Switch
    Last Post: 10-10-06, 11:24 AM
  4. Rear brake light problem
    By miggy in forum Africa Twin
    Last Post: 01-12-04, 09:47 PM
  5. Front brake light switch
    By Lord Stig in forum Africa Twin
    Last Post: 18-11-04, 09:50 AM
