Will a twin disc front end off ,say a 2000 TA600, fit straight onto an older 1995 model with a single disc? Are the fork springs the same?Any other alterations needed?
I'd imagine you should be ok with the swap, only problem you may have is the mastercylinder bore from the single disc bike being made to operate the 2 disc setup - suck it and see, worst case - you'll need a m/cylinder yo match.
'02 Transalp
'01 Transalp (Transrat)
'98 Transalp
'91 NC30
'08 Hornet (Vanessa's)
Many thanksOriginally Posted by piguglyshandydrinker
