Results 1 to 9 of 9
Thread: Swinging arm Chain Slider
    babybadger's Avatar
    Mar 2006
    SE London
    Has anyone done a 'how to' and what is involved? I have heard that it is swing arm off, to get this fitted.
    babybadger's Avatar
    Mar 2006
    SE London
    Re: Swinging arm Chain Slider
    Quote Originally Posted by babybadger
    67 viewings and no ideas....this site is going down hill
    Ourico_Voador is offline Junior Member
    Jun 2006
    Portugal
    yes, in my limited knowledge, you have to remove the swing arm to replace the chain slider.
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    Yes it needs removing but it's an opportunity to re-grease the s-arm & linkage bearings. Get a Haynes manual from Halfords if you fancy having a go. The slider wraps around the front of the arm and the 'top & bottom runs' are joined by a strip that bolts to the side of the arm, so unless you cut it it's a complete rear end strip.
    BlindPugh's Avatar
    UK
    Not too difficult a job gettin the Swing Arm out
    Remove Rear Wheel and unhhok the rear brake hose from the swing arm.
    Disconnect the lower shock mount bolt and the rising linkage pivot block good time to check the bearings and regrease them.
    Remove the Swing arm pivot bolt - usually a combination of gently tapping it and turning the bolt will ease it through the frame , swing arm and engine.
    Remove chain slider and fit new one - grease swing arm bearings and pivot bolt.
    Re-assemble using a torque wrench on the main suspension bolts.
    babybadger's Avatar
    Mar 2006
    SE London
    Quote Originally Posted by BlindPugh
    Thanks for that. Are there modified sliders around that are more hardened than the originals? Main stealer quoted 40ish gbp for one. I would rather pay more and get the right one!
    babybadger's Avatar
    Mar 2006
    SE London
    Does anyone have the torque wrench settings for these bolts?
    SMARSUKI is offline Member
    Apr 2007
    dyffryn ardudwy
    I manage it with removing swingarm put the slider in bioling water for 10mins and with a screw driver you can ease it round the arm from the top using chain as guide
    While the thing is apart check the bearings and replace or repack with grease before reassembly.
  1. New chain etc
    Last Post: 23-06-10, 05:41 PM
  2. New Chain
    By zorza in forum Africa Twin
    Last Post: 04-07-06, 01:20 PM
  3. CHAIN FOR AT.
    By ruterovenezuela in forum Africa Twin
    Last Post: 06-04-06, 07:26 PM
  4. Chain Slider
    Last Post: 10-11-05, 05:35 PM
  5. Chain(again)
    By mal in forum Africa Twin
    Last Post: 17-03-05, 09:51 AM
