Results 1 to 10 of 11
Thread: Centre Stand Query
    veshgp is offline Junior Member
    Oct 2006
    Johannesburg, South Africa
    Centre Stand Query
    Whats the trick with putting a Transalp onto its centre stand and taking it off? It takes a lot of effort to try and push down on the stand inorder to lift the bike up.
    Also, how far off the ground should the rear wheel be once the bike is on the centre stand?
    russh's Avatar
    Apr 2006
    Oxfordshire
    I find being 6'2" and 15.5 stone helps
    I just get the ball of my left foot on the large foot lever thing on the centre stand, then put all my weight on this while lifting on the grab handle of the back rack rather than using honda's centre stand lifting handle underneath the side panel.
    I would say this is quite easy, except this morning when in the process of lifting the bike onto the stand my foot slipped off and I fell over the bike, luckly my fall was broken the handlebars on my neighbours garden wall
    Oh, and taking the bike off the stand, I again use the back rack handle and just pull forwards and slightly upwards at the same time.
    F800GS ...broom broom yeah!!!
    babybadger's Avatar
    Mar 2006
    SE London
    Much the same, but as I have a top box, big givi, I use the rear left footpeg hanger and lift as well as pushing down on the centrestand. Don't for get to grease the pivots etc. as this will get harder and harder as the winter goes on..........Mine is caked in crud and is difficult to lift and doesn't spring up when I roll it off the c/stand.
    It should stand about 50mm off the floor when on the stand. (it does depend how worn the spring/shock is I suppose)
    If you are careful you can put the bike in gear with engine running and wax/lube the chain while it is spinning round.
    Make sure the bike's front wheel is facing a wall for obvious reasons........
    Oct 2006
    Quote Originally Posted by russh
    haha, the same thing happened to me. This spill resulted in a cracked braked lever, scratched handguard and a bruised ego coz my cute neighbour saw me dropping it .
    In future I will only put the bike on the center stand when I need to do maintanence work and when I have some else there to assist me
    Oct 2006
    Quote Originally Posted by babybadger
    The rear wheel on my bike sits about 30mm off the ground when the bike is on the center stand. I can still turn the wheel by hand, so I'm assuming this is fine.
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    Getting it on the stand is more to do with leg power than lifting.
    My tyre is only about 20mm off the floor (130 Distanzia).
    Austin's Avatar
    GARSTANG
    except I am a little more than 15.5 stone so its even easier and I use my right foot. The leverage comes from your foot/leg not your hand/arm and once its moving back keep it going. There is a technique (not just for TAs) and I think you can either do it easily, or you can't.
    babybadger's Avatar
    Mar 2006
    SE London
    Quote Originally Posted by Recycler
    Don't forget that I am running a BT45 on the back and I have a Koni Shock as well, so both non standard.......
    Cyborg's Avatar
    Cyborg is offline Junior Member
    Oct 2006
    Smallfield, Surrey UK
    I find that pulling the bike back a little and then pushing the stand down helpful, as it uses the weight and momentum of the bike to raise it onto the stand. As there's no way I can get it onto the stand from a standing start without assistance.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    Not a great idea
    PLEASE DONT DO THIS
    I had a friend who was using the above technique to clean & lube his chain - he's now minus a finger after a small lapse of concentration.
    PLEASE DONT DO THIS
    SteveT
  1. Centre stand
    Last Post: 31-01-09, 10:30 PM
  2. Centre Stand?
    By willb in forum Africa Twin
    Last Post: 20-09-06, 10:01 PM
  3. HELP!! Centre stand?
    By Bobby boy in forum Africa Twin
    Last Post: 31-03-06, 01:00 PM
  4. Centre Stand for @
    Last Post: 14-10-05, 06:52 PM
  5. Centre Stand
    By Connor in forum Transalp
    Last Post: 18-07-05, 09:52 PM
