I've never had a problem with a battery on a bike, mine is original on an 02 registered 2001 bike.
As mentioned above, check the battery voltage - ideally above 12.5v then start the engine and check voltage at battery terminals - should be 12.5 to 14ish max, if thats ok, check the soleniod and main fuse connections for corrosion (this is mounted onto the battery securing plate), clean any terminals and smear with petroleum jelly or coppa-slip to protect them.
Check the battery voltage after a while to see if it had dropped much.
Alarms are notorious for killing batteries, has the bike stood in a dealers for years before first registration?
Good luck, Phil
'02 Transalp
'01 Transalp (Transrat)
'98 Transalp
'91 NC30
'08 Hornet (Vanessa's)
