Results 1 to 3 of 3
Thread: which renthal bars
    harrisphil Guest
    which renthal bars
    has anybody fitted renthal bars to a 650 transalp
    if so which bend did you fit ?
    do they clear the fairing on full lock?
    are they any higher/lower than standard bars?
    thanks
    phil
    wheeliebin's Avatar
    N/A
    I use to have the Renthal Dakar High bars fitted, they were wider but slightly lower, ended up fitting 30mm risers to get them how I wanted.
    Think Mudwiz has a higher Rethal bar, but can't remember which sort.
    Mudwiz's Avatar
    Off hand mine are 697, but I'll check.
    They are very high and narrow, off "playbike" sort of thing. Needed to extend clutch and brakes to fit, but suit me perfectly.
    (Only issue is about 1-2" of grip doesn't have 'bar in it, but its only a problem when picking it up from the mud!)
  1. Renthal Bars
    By cabbage2404 in forum Africa Twin
    Last Post: 11-02-10, 10:28 AM
  2. Renthal Bars & Acerbis Handgaurds
    Last Post: 30-11-07, 08:11 PM
  3. Renthal - do I need the brace?
    By fridge in forum Transalp
    Last Post: 12-02-07, 08:47 PM
  4. Renthal Dakar High bars vs Standard AT bars
    By lootch67 in forum Africa Twin
    Last Post: 08-01-07, 11:46 PM
  5. Renthal Bars
    By ean in forum Africa Twin
    Last Post: 28-07-05, 05:24 PM
