Results 1 to 10 of 19
Thread: bleeding brakes
    wab's Avatar
    wab
    wab is offline Member
    Jul 2006
    biggleswade, beds
    bleeding brakes
    Hello again i have 2 probs that i need some ideas for but i will do 2 seperate posts.
    Firstly i junked the medieval front brake hose system on my 88 ta this morning and fitted a shiny new goodridge version...lovely.
    Problem is even after hours of pumping the lever the traditional way, there is no pressure in the system, like theres an airlock. Drained the cylinder,it was abit cruddy but nothing sinister,and tried several other tricks but nothing works. Tried both bleed nipples but couldnt figure out why the cylinder requires a bleed nipple??
    The haynes manual recommends a vacuum operated brake bleeder but i wondered if anyones suffered the same probs/knows any tricks/where the hell you get a vacuum bleeder from.AAAAAAAAAAAAAHHHHHHHHHH!!!
    Billy
    Cyborg's Avatar
    Cyborg is offline Junior Member
    Oct 2006
    Smallfield, Surrey UK
    I bled mine in the same manner as a car with the same non-return valved rubber tube. Mine is the twin disc version and I had no problems after fitting the braided hoses and bleeding the system.
    To fill the brake line, connect car type non return bleeding tube to caliper nipple
    1/ Open bleed valve on caliper
    2/ Apply brake
    3/ Keeping brake applied close the bleed nipple
    4/ Quickly release brake lever
    When fluid (eventually when you feel old and weary after doing the above lots of times) starts coming out of the bleed tube attached to the nipple, bleed as below
    1/ Hold brake lever
    2/ Open and close the bleed nipple
    3/ Release brake lever
    Repeat for other side if doing the front calipers.
    wab's Avatar
    wab
    Jul 2006
    biggleswade, beds
    this is the thing though yen all those points you so kindly pointed out were tried over and over for several hours but the fluid wouldnt get past the cylinder so didnt get a chance to fill the line itself.
    Took the line off and tried just bleeding the cylinder direct but theres no pressure what so ever when you pull the lever in, like the plunger isnt working.But nothing apart from the line has been touched so why would it stop working.
    So i wonder if the vacuum bleeder would help draw the fluid out and down through the line??
    harrisphil Guest
    brakes
    if the fluid is not getting past the master cylinder it sounds like the piston is stuck in the closed position
    Remove the master cylinder banjo bolt and push the piston back towards the brake lever using a small screwdriver
    using the screwdriver and the brake lever you should be able to feel the piston move
    flush out the master cylinder with clean fluid and bleed as normall
    as a final flourishpull the brake lever back towards the bars and tie in place using an old inertube or elastic cord in the morning all the air will have rissen to the top and you will have brakes
    ger
    ger is offline Member
    Apr 2006
    Near Glasgow...Scotland
    Hi there,
    Changed to stainless on my TA in the summer. Bleeding was a complete PIA, just as your are experiencing. I had a Mityvac vacuum pump lying around from a previous bad bleeding experience on my little Hotrod. Very fiddly but got there in the end.....
    http://cgi.ebay.co.uk/Mityvac-One-Ma...QQcmdZViewItem
    cheers
    Gerry
    wab's Avatar
    wab
    Jul 2006
    biggleswade, beds
    Ahh Gerry
    You are my saviour, i was beginning to think i had messed something up.
    Thankyou for your message and for the very nice link to the tool on ebay, thats a good price.
    Im so glad thats the answer to my pig of a weekend so im off to purchase myself one of those beauties!!
    Billy
    mal's Avatar
    mal
    mal is offline Senior Member
    Aug 2004
    GLASGOW
    post
    Just a thought, would it be possible to bleed the brakes using a medical syringe, open the caliper bleed valve, connect a tube from a syringe to the nipple& carefully inject a syringe full of brake fluid back to the master cylinder, you would have make sure you don't blow the fluid everywhere would it work? possibly, worth a try, you would obviously need a reasonable size of syringe i presume you would get one in a Chemist shop
    icenian's Avatar
    Jul 2004
    Votadinia
    I've changed brake lines twice on the Africa Twin.
    The first time it took about two hours. The second time round I had the Mityvac pump and I was all finished in about 10 minutes! Unless you're really skint, just buy the Mityvac, you'll be so glad you did. Even "regular" brake bleeding is quicker and easier.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    Medical syringe
    I use a catering syringe thats used for icing cakes (just done front & rear on my '91 TA) . I draw the fluid down to the caliper from resevoir but am mindful not to put too much vacum on the system in case seals give in. At same time I operate the brake lever which keeps things moving nicely.
    Just the ramblings of an ageing teenager - honest.
    TTFN,
    SteveT
  1. Brakes again
    By markh in forum Africa Twin
    Last Post: 25-02-07, 05:29 PM
  2. BRAKES.....
    Last Post: 22-01-07, 08:53 AM
  3. Brakes
    By z-weiser in forum Mechanical Advice
    Last Post: 29-12-06, 09:49 PM
  4. I have a bleeding problem
    By Maverick in forum Chatter
    Last Post: 14-02-06, 06:15 PM
