Re: Carburators
Originally Posted by
Conquistador
Carburetors
I have a 2004 XL650V and recently rode at very high altitude here in Chile, up to 4700m. I would barely run over about 3500m. The symptoms were lots of bogging, loading up with gas, black smoke, almost zero power. It ran a little better at very low throttle position under 3000 rpm. As soon I descended, all symptoms returned to normal. Later in the trip I checked the needle valves to see if they could be adjusted, - no go –they are in a fixed position.
So the questions are:
What carburetors does this bike have, I think I remember reading about Keihin CVK 34.
Has anybody done any jetting modification for altitude? I‘d like an adjustable needle and smaller main and pilot jets – any ideas as to sizes I should try?
What is an easy way to sync these carbs after I’ve monkeyed with them. Do I need any tools?
Nice site you have here – it’s great to find support for a good bike. Check out my trip at ADV rider
http://www.advrider.com/forums/showthread.php?t=188978
Saludos,
Hi, Saludos and welcome.
Sorry to hear the bike is running poorly at altitude, have a look at the post on air intake, drilling the airbox may help a little, otherwise rejetting is the answer, I fitted smaller mains to help with fuel consumption, I have yet to have it dyno'd to check on fuelling, bike still runs fine at sea level, jets are #125's (stock are 132).
As for adjustable needles???maybe fitting carbs from an older 600 Alp as I think they have adjustable needles and are still 34mm.
'02 Transalp
'01 Transalp (Transrat)
'98 Transalp
'91 NC30
'08 Hornet (Vanessa's)
