Originally Posted by
alpslapper
ok for front and rear cylinder read front of the v and rear of the v shaped thingy that makes the bike go vroom vroom
:P
thanks for the replies.
Coolant is just on the line.
What do I add to it - is the coolant just a straight mix of antifreeze and water??
thanks
and merry christmas one and all
tom
Coolant should be at the max line but only when the engine is at normal running temp so check it (by looking, not opening) when you get home from somewhere. Mix is 50/50 antifreeze and distilled water. If mine needs topping up, I put a rag around the cap on the coolant bottle before opening. It shouldn't spurt but no sense in being unprepared eh. I coulda been a boy scout you know if it wasn't for these damned horrible knees.
