Re: Fitting headlamp bulb on xl650v- Help!
Originally Posted by
stumpylegs
Spent 2 hours last night trying to figure out how to get access to my headlight bulb to change a blown bulb. Found access really difficult and even when i managed to get my hands on connector i couldn't pull it off. Handbook suggests you just pull off connector, remove rubber cap then press on spring clip. The connector seems to have a rubber cover over it and despite my best efforts nothing would move.
Ended up taking bike to dealer- total cost including £4.50 bulb was £52
(1hr labour charge+vat was£47). Use bike every day for work and can't afford to pay this every time a bulb goes.
Any tips on best way to approach this?
On the AT the block connector that fits on the back of the bulb will not pull off unless you squeeze it on both sides (left and right edges). If you don't press at this point, mine won't even budge. The rubber cover should just come away once the block conector is removed. After that the spring clip should be easy to unping, then it will hang there unless you dislodge the other end. After this you carefully pull the bulb out, put the new one in (without getting any fingerprints or grease on the glass part) and fight with the spring clip until it holds the bulb firmly. Put the rubber shield back on with the drainage part facing down (a sort of a v-shaped bit) and refit the block connector with a push.
Of course this is my bike, never done a 650 Transalp but it must be similar.
