Hi Slimjim the nylon cog in the drive usually breaks , Also inside the drive is a washer with two prongs that stick out to engage the Nylon cog. When the nylon cog breaks it normally bends the prongs so that they do not engage anymore . If you are able to remove the front wheel " don,t know if you are able to " if not Remove the speedo cable before it breaks , The cable is around £10 the nylon cog if you can get it on its own is about the same or you might have to buy the washer and DRIVE as well about £50 . Dave silver spares in the links section i think they sell the nylon cog on it,s own. ALSO when you put it back together be sure to use the proper grease AS common or garden grease will make the nylon brittle and break in no time . I don,t remember the name for the Propper Grease but i am sure that some good soul will post up the name of it. fw750x
Sometimes when i think the world,s all bad , Then i see some people on Motorcycles it makes me take another look. Steve Mcqueen.
