Results 1 to 8 of 8
Thread: homemade sump guard?
    moon's Avatar
    moon is offline luddite
    Mar 2005
    Auxerre, Burgundy
    anybody tried making one for a 600?
    I can't afford to buy one, I can weld steel but not ally & have plenty off cuts of steel lying around at work. With some fairly basic tools I reckon I may be able to cobble something together.
    If any one's already tried Im looking for the pitfalls to avoid, what to fix to etc etc.
    Ta
    MooN
    boboneleg's Avatar
    boboneleg is online now Senior Member
    Bristol
    Hello Moon,
    make two and sell one to Pedro
    2003 Transalp
    2004 KTM 950 ADV
    1998 Suzuki DR350
    Chad's Avatar
    wickford,essex
    Quote Originally Posted by boboneleg
    Hello Moon,
    oooooooh you beatch
    Pete Rock's Avatar
    Pete Rock is offline Good Moaning
    Portugal
    Everybody´s a comedian these days Chad
    If you´re going to send me anything better make it a new water pump though Moon
    harrisphil Guest
    sumpguards
    I have made them in the past for trials bikes and they were just a smooth flat piece of alloy bent up at the front bolted on front and back (use countersunk bolts at the back to keep it smooth)
    great for sliding over tree roots and rocks
    fit a piece of sponge between the guard and bottom of the engine to stop rocks and a build up of mud.
    It is only in recent years that the fashion for having sump guards that come 1/2 way up the side of the engine these are just welded on wings
    If you cant weld Alloy its not expensive to have a local engineering shop weld them on for you
    moon's Avatar
    Mar 2005
    Auxerre, Burgundy
    Thanks "Harrisphil" Noted the tip about countersunk bolts & the Sponge (not sure I'd have thought of that...). I can't weld alloy, but was thinking of doing it in stainless (cos it won't cost me anything & I can weld it meself). though I was wondering what sort of thickness to use.
    3 or 4 mm? (less than 2 I can't weld more than 4 will be too lumpy & heavy I reckon).
    thoughts?
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    I'd say 2mm stainless would be ore than strong enough for general use.
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    moon's Avatar
    Mar 2005
    Auxerre, Burgundy
    I'll have to see if I can weld 2mm, or if I just blow holes in it, I can probably solder it (if that's the correct term) but I've less practise at that.
    I'l probably try & make the first model (cardboard) this week sometime.
  1. Sump Guard - anyone else want one?
    By piguglyshandydrinker in forum Transalp
    Last Post: 16-02-08, 09:26 PM
  2. NEW SUMP GUARD / TOOL BOX
    By anton88 in forum Dominator / FMX
    Last Post: 18-09-07, 06:00 PM
  3. Black Sump Guard
    By fw600vj in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 20-01-06, 09:09 PM
  4. sump guard rattle
    By DaveOrme in forum Africa Twin
    Last Post: 17-05-05, 06:39 PM
  5. The sump guard
    Last Post: 08-11-04, 04:10 PM
