Results 1 to 9 of 9
Thread: Base plate for side stand
    Byker is offline Junior Member
    Norwich
    HI,
    Has anyone tried fitting a bigger base plate to the side stand on the TA.
    Outside my house is all gravel and the side stand tends to dig in making the bike lean over too much. I have a plank of wood on the ground at the moment.
    Any suggestions would be welcome.
    [Too old to die middle aged]
    Re: Base plate for side stand
    Quote Originally Posted by Byker
    HI,
    All my Africa Twins have had a piece of car tyre bolted onto the foot of the sidestand. You can park on quicksand with that!
    babybadger's Avatar
    Mar 2006
    SE London
    http://www.halfords.com/webapp/wcs/s...tegoryrn_33975 for £1.99 you cant go wrong.....
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    I did have a plastic sidestand puck permanently pop-rivetted on, the alloy rivet failed after a while, I now have a lump of 2mm stainless plate bolted in place.
    Works a treat.
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    oily is offline Junior Member
    Australia
    Hi
    I use a square of 5mm aluminium.
    This has been drilled and tapped so the screws with flat washers
    bear against the side of the original sidestand foot.
    Loctite in place of course.
    cheers
    Cotswolds, UK
    I remember while staying on muddy camping-sites putting the side-stand inside- or on the nose of one of my boots to avoid mayhem. Having size 13 myself means you can park it in a lake if necessary. Looks quite funny as a bonus. Not recommended if you have fancy and/or soft boots, and it's also unconvenient if it's the only foot-wear you have available (unless you were not planning to go anywhere in the first place ).
    alpslapper's Avatar
    Essex
    Pah !!! Real bikers use crushed beer cans
    willb is offline Senior Member
    Cambridge
    I've seen the crushed beer can used by a biker at the V Festival last year.
    My AT has a bit of metal welded to the base of the sidestand, I can take a pic if you want. Wasn't done by me but did seem a useful addition!
    BMW F800GS, Touratech Panniers, Givi Topbox, Scott Oiler, Metal Mule screen
    Used to have:RD07, 2001, Touratech Panniers, Nonfango topbox, baglux tank harness, Scott Oiler
    Norwich
    Thanks to everyone for their suggestions
  1. side stand movement?
    By shnesdi in forum Transalp
    Last Post: 22-01-07, 02:23 PM
  2. Bash plate
    By markh in forum Africa Twin
    Last Post: 16-12-06, 01:27 PM
  3. Side Stand Strength
    Last Post: 25-05-06, 03:19 PM
  4. Side stand question
    Last Post: 27-06-05, 06:25 PM
