Coolant
Results 1 to 6 of 6
Thread: Coolant
    T ALPER is offline Member
    Aug 2016
    west yorkshire
    Coolant
    What type of coolant are you using, I don't know whether to use ethylene glycol silicate based or the later type O.A.T (organic antifreeze technology) does not contain silicate. Im'e not bothered about the antifreeze aspect as the bike (650) never sees frost but wondering about the lubrication/anti corrosion properties. Has anybody had water pump or any other problems using the silicate based stuff?
    piguglyshandydrinker's Avatar
    piguglyshandydrinker is offline Senior Member
    Lancs UK
    Re: Coolant
    Whenever I change mine on any bike, I flush the system thoroughly then refill with modern pink/orange long life stuff. Never had an issue.
    Aug 2016
    west yorkshire
    Re: Coolant
    Thanks for the reply, think I will play safe then and use the pink O.A.T stuff. Im'e guessing you just flush out with a hose and tap water?
  5. Remove Advertisements
    jamie92j's Avatar
    jamie92j is offline bike nut
    Aug 2008
    The 'Shire'
    Re: Coolant
    +1 for OATS
    Halfords do big tubs of the stuff cheap!
    everything is OK
    Central Asia 2014
  7. The Following User Says Thank You to jamie92j For This Useful Post:
    T ALPER (22-03-17)
  8. #5
    Lancs UK
    Re: Coolant
    Quote Originally Posted by T ALPER View Post
    Yes, then fill & run for a while then drain then flush again.
    I believe it's not best practice to mix different types of antifreeze.
    Gawd knows why motorbikes are stuck in the dark ages & still using old tech coolant.
  9. The Following User Says Thank You to piguglyshandydrinker For This Useful Post:
    T ALPER (22-03-17)
  10. #6
    Aug 2016
    west yorkshire
    Re: Coolant
    Thanks for the replies fella's
  1. Coolant
    By Oro in forum Africa Twin
    Last Post: 07-11-15, 03:26 PM
  2. Coolant gone!
    By AckAckFlack in forum Varadero
    Last Post: 05-03-10, 06:24 AM
  3. coolant
    By yoashman in forum Africa Twin
    Last Post: 21-07-09, 11:44 AM
  4. Using coolant.
    By MR.T in forum Transalp
    Last Post: 25-04-08, 12:53 PM
  5. coolant??
    By saintvice in forum Africa Twin
    Last Post: 05-12-05, 04:43 PM
