Results 1 to 3 of 3
Thread: Foam air filters and jetting
    default Guest
    I have a trip planed for the Transalp and would like to have a washable air filter. Not too keen on K & N filters and would prefer a foam filter as I think they offer the best filtration. My TA is a 04 and does suffer from poor carburetion; most noticeable is a slight hesitation around 2500 rpm and a flat spot under hard accel from 5000 rpm. The flat spot is over come with a new standard air filter but returns after approximately 6000 miles.
    This is work in progress so I will keep you posted.
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    Re: Foam air filters and jetting
    The 650's do run rich as stock.
    I feel you may not be far off the mark with 128 mains & a foam airfilter.
    I'm running a de-catted bike with stock filter & airbox & 125 mains, carburation is perfect, fuelling throughout the revrange is excellent, (needles are unaltered).
    Pilot screws turned out an extra 3/4 turn to richen the bottom end.
    Max power is 2hp up on stock at just over 49, fuel consumption & throttle response is improved everywhere.
    Hope that this helps a little, let me know how you get on.
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    Leigh (& Saltburn!)
    Nice work Activemoto, interesting to know that the 125 jets will work with a foam air filter.
    Where did you get the pipercross?
    Keep us informed of the progress.
    '02 Transalp
    '98 Transalp
    '91 NC30
  1. Foam air filter for 650 TA
    By default in forum Transalp
    Last Post: 14-03-09, 03:11 PM
  2. carbs jetting
    By tsak in forum Africa Twin
    Last Post: 14-10-06, 11:05 AM
  3. AT Air Filters
    Last Post: 22-06-06, 05:40 PM
  4. Air Filters....who needs em!
    By Dilbert in forum Africa Twin
    Last Post: 30-08-05, 08:49 PM
  5. K&N Filters
    By garry in forum Africa Twin
    Last Post: 20-01-05, 10:16 AM
