OK all, some of you have fitted 'high capacity reservoirs', chopped the cat, some have even gone to rejetting....
Now it's time to up the ante
I was baulking at buying a sump protector, partially for financial reasons, partly for aesthetics - I want the bike to look fairly standard.
Here's one I knocked up from a piece of 3mm alloy plate and a 2lb lump hammer.
Then there's the lever protectors, again the same lump of 3mm ally, again they won't offer the ultimate in protection but will help a little....
I just need to replace the barend bolts with either countersunk, or quality domed roofing type bolt's - to match the rest!
To the far left is the homemade PDA/satnav holder, a besopke bit of kit made from the galvanised plate salvaged from the back of a knackered gas fire.
Now onto the 'Sh*t Kit' - ftted, succesfully for the second winter, just prior to removal this evening.
Made from various bits of 2mm rubber fastened by self tapping screws and cable ties.
It really does do a fantastic job of keeping crap out of the front of the engine (where you can't get into to clean it off), the left hand radiator is also blocked off with the same stuff. The bike warms up very quickly and keeps a constant temp, even in the coldest weather.
The gauge only starts to rise when the air temp rises above 15*C and slow foward speeds.
Future thoughts.....
There seems to be a lot of wasted space, between the inner & outer fairings, would make a useful storage compartment, don't ya think - waterproof's/innertubes etc???
Also, now with the cat has been removed, there is quite ammount of space that is dying to be filled......
Watch this space
