Results 1 to 5 of 5
Thread: Removing/Replacing the brake pedal on the XL650V
    BuckarooBanzai's Avatar
    BuckarooBanzai is offline 8th Dimension Adventurer
    Jul 2005
    West Cornwall
    Question Removing/Replacing the brake pedal on the XL650V
    Has anyone else been reduced to a gibbering wreck by this task? I can remove the brake pedal by displacing the RH Footrest bracket, and then undoing the pinchbolt with a ratcheting pivot-headed 12mm spanner. Putting it all back again is a different matter! If you leave the spring on the footrest bracket attached, fitting the pedal back into the thingamabob thats attached to the brake mechanism is almost impossible, and lining up the punch mark so that the pedal is at the correct height just can't be done (unless you have X-ray vision). If you leave the spring unattached, how do you reconnect it when the pedal is back in place and the footrest bracket tightened up? At the moment (after much swearing) my brake pedal is now reattached, but sitting at about 4 o'clock in relation to the bracket!
    There must be an easy way to do this which, as an amateur bodger, i'm just not seeing - can someone please put me out of my misery and tell me how it's done?
    Ta.
    HeebyGeeby's Avatar
    HeebyGeeby is offline Junior Member
    Mar 2007
    Dublin
    Re: Removing/Replacing the brake pedal on the XL650V
    I managed to remove and replace without removing the footrest bracket, I just removed the two brake cylinder bolts, dropped the cylinder and bent my wrist to a 143.21 degree angle. The main spring never came off.
    Replacing it was a matter of trial and error for me I'm afraid, fitting it, checking position, replacing it etc.
    Honda could have made it all far more accessible if they'd felt so inclined.
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    Jul 2005
    West Cornwall
    That's just what I was after - Mr Haynes is rarely of much help in these matters! Many thanks guys!
    RainMan's Avatar
    Nov 2006
    Cork, Ireland
    Quote Originally Posted by HeebyGeeby View Post
    Ah now I understand why I was having problems, I was only bending my wrist to a 140.32 degree angle.
  1. replacing idiot lights??
    By shaneh in forum Varadero
    Last Post: 02-11-06, 07:27 PM
  2. Replacing inner tubes?
    By billy in forum Wheels, Tyres & Tubes
    Last Post: 20-09-06, 06:14 PM
  3. replacing the topbox
    By caRnaf in forum Africa Twin
    Last Post: 26-02-06, 05:38 PM
  4. Replacing chain
    By Rolo in forum Africa Twin
    Last Post: 21-10-05, 12:54 PM
  5. XL650V versus YZF R1 and GSX-R 600
    By Bored At Work in forum Transalp
    Last Post: 26-11-04, 01:32 AM
