Results 1 to 6 of 6
Thread: spark plug removal
    gaz-toon is offline Junior Member
    Apr 2007
    newcastle
    spark plug removal
    HELP!!!!!!! i'm getting very frustrated at not being able to change a spark plug on my 99 transalp 600. Got three done no problem but can't get out the fourth. The one that sits behind the radiator at the front. I've removed side panel and radiator to gain access to the cylinder, i can see the plug (which looks like hasn't been changed for a while) but can't get a socket onto it. PLEASE HELP!!!
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    Re: spark plug removal
    Do you have the proper Honda plug socket, it's in at a similar agle to the hidden one on the rear cylinder. It's doable with a little patience.
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    rlkat's Avatar
    rlkat is offline '99 Varadero 1000
    Oct 2005
    North Berwick
    Yep, it's a bugger if you haven't got the Honda plug spanner.... or a Dad who has a lathe that can machine a shamfer on a normal plug socket. Definitely worth buying the original item from David Silver.
    rob
    FatFergie's Avatar
    Mar 2006
    You can take it out without moving anything other than the side panel...................
    if you've got the honda plug spanner
    get one
    best thing since sliced bread (actually it's better).
    RainMan's Avatar
    Nov 2006
    Cork, Ireland
    Quote Originally Posted by FatFergie View Post
    get one
    Shame the same thing can't be said about the 650
    jpd
    jpd is offline Member
    Mar 2007
    ireland
    ya need a narrow wall socket
  1. XR400 Spark Plug
    By DaveS in forum XR
    Last Post: 15-06-07, 02:39 PM
  2. Spark Plug colour
    By shnesdi in forum Transalp
    Last Post: 25-04-07, 08:17 AM
  3. Spark plug problem.
    By boboneleg in forum Africa Twin
    Last Post: 01-04-07, 10:18 AM
  4. The spark plug question - again
    By darthDassie in forum Africa Twin
    Last Post: 15-12-06, 04:29 PM
  5. Spark plug change
    By banger in forum Africa Twin
    Last Post: 13-09-04, 01:40 PM
