Results 1 to 10 of 11
Thread: heated grips
    brownie2 is offline Member
    Jun 2007
    newton abbot
    heated grips
    hi, can ne1 recommend a decent set of heated grips and a idea where to hook them in, pics would be gr8 if pos.
    was told by a local honda dealer to only use a honda set due to the amp requirement,
    24ftlb is online now Senior Member
    Oct 2005
    Sheffield, South
    Re: heated grips
    Ive got the oxford heated grips. Not the very latest digital ones but the model before with the rotating temp adjuster. 35 quid from Halfords. Best thing ive ever bought for the ta. Easy to fit, easy to wire. In winter gloves I cannot hold the grips if they are set at anything above half.
    They claim a maximum temp of 55.c / 131 fahrenheit, and im not going to dispute their claim.
    A bargain for the money with a 2 year warranty.
    I wired in to the fan circuit by the fuse box for the switched live. Other wires obviously to battery. Just find the power out side of the fuse box and splice or solder your wire in.
    Paul
    Jun 2007
    newton abbot
    Re: heated grips
    thanks 4 that, was thinking of the oxford 1's,
    Wee Jack's Avatar
    Wee Jack is offline Short Fat Bald Member
    Jul 2006
    An Island Somewhere in the Clyde
    Re: heated grips
    Quote Originally Posted by brownie2 View Post
    The Honda grips are good , but they are expensive. your dealer is trying to scare you with the power draw story - he's talking total pants. There is plenty of "capacity" in the Alp charging circuit to cope with heated grips of any sort.
    Just make sure you pick up a live that is switched by the ignition so that the grips switch of when you switch the bike off, otherwise you will end up with a very flat battery in the morning.
    2011 Triumph Tiger 800 - "Black Pussy" - MMMM Nice !!!
    Pete Rock's Avatar
    Pete Rock is offline Good Moaning
    Portugal
    Re: heated grips
    My dealer told me that the only difference between the Honda grips and the Oxford ones, in terms of power draw and quality, is the price
    Jun 2007
    newton abbot
    Re: heated grips
    thata what i expected, will i get a diagram in the kit to show which wire to latch onto?
    or ne1 got ne pics, please. do i have to connect to a live and then earth it to the frame?
    sry ,i'm not up on the electric side of these things, the actual fitting i'm fine with.
    Oct 2005
    Sheffield, South
    Re: heated grips
    There are 2 wires for the oxford grips. 1 a switched live and the other is the negative. pick up the switched live from the output side of the fuse box. i used the fan circuit as its not overly likely the fans going to be on at the same time as the grips.
    Paul
    LUNLUNZAI's Avatar
    LUNLUNZAI is offline Vara-Alper
    Jul 2007
    SOUTHAMPTON
    Re: heated grips
    I fitted a pair of Honda Grips to my TDM 900 B4 (CONNECTED TO HEADLIGHT).
    The ex-police transalp I got recently has already had a pair of Honda heated Grips on. However, they do not work.
    I suspect there is bad connection some where as all the connections are expose and barely covered by the rubber covers came with them.
    I can see there are some green corrosion, what is the best to regarding the nasty corrosions? GT85, WD40 that sort of things ?
    I am also looking for a bar end cap as one of them has gone
    FatFergie's Avatar
    Mar 2006
    Re: heated grips
    I've got a set of oxford grips and am reasonably happy with them. The connectors are a bit flimsy but otherwise Ok.
    I'd advise you to take the bars off to fit them because the glue sets very quickly, Do a dry run first to make sure everything fits and lines up without fouling the controls. Taking the paint off and smoothing the bars helps because the grips are quite tight.
    Mine are a couple of years old so things might be different but I didn't get a bike specific diagram. I broke into the ignition switch live just under the switch but it would have been neater to use the fusebox. I've got a 600 so I'm not au fait with the (presumably) 650 that you have but I'm sure there'll be something similar to use.
    Have a look at this, I'm not a fan of scotchblocks but wouldn't stop anyone using one.
    http://www.xrv.org.uk/wiki/index.php...g_heated_grips
    And these, similar to BMW style heaters, they fit inside the bars and mean you don't have the wires hanging around your controls and you don't have to replace your grips.
    http://happy-trail.com/ProductInfo.a...=SYMTEC-210019
    Jun 2007
    newton abbot
    Re: heated grips
    thats just ,what i was looking for m8 cheers, i also have the 600 (99)
  1. Oxford Heated Grips vs Motrax Headed Grips
    By Wold Rider in forum Africa Twin
    Last Post: 13-12-08, 09:58 PM
  2. Heated grips...... at last :)
    By russh in forum Accessories
    Last Post: 18-11-06, 10:03 PM
  3. Heated grips ...
    Last Post: 27-01-06, 03:37 PM
  4. heated grips
    Last Post: 13-11-05, 07:26 AM
  5. Heated Grips
    By DM in forum Chatter
    Last Post: 26-06-04, 01:15 PM
