Results 1 to 7 of 7
Thread: Down gearing Transalp 650
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    I'm looking to reduce the overall gearing of the Alp (ANOTHER New bike....., does anyone know of a 14 tooth front sprocket & supplier?
    Cheer's, Phil
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    Mudwiz's Avatar
    Re: Down gearing Transalp 650
    try www.intobikes.co.uk , I run a 14t front (-1) and a 49 rear (+1), makes the bike feel a lot quicker, but its really hard to hit the ton! Works a treat in the sticky/slippy stuff though, and is much better on steep downhills.
    The sprockets are by Afam, and seam to wear well, even abused with sand etc. I run mine with any old o ring 525 chain, with a clip link, currently Triple S brand?
    Leigh (& Saltburn!)
    Quote Originally Posted by Mudwiz View Post
    OK, cheer's mudwiz, I'll check it out.
    As for struggling to hit the ton, try it on an Alp with no fairing... (come to think of it you probably have!!!)
    '02 Transalp
    '98 Transalp
    '91 NC30
    Mudwiz's Avatar
    Naked front end with a mx high mudguard, high narrow bars! Shakes its head a bit, but it can be done. Just need to keep your weight right forwards, lean back and cover 3 lanes in 1 go!!
    (Hence fully faired up again! No more Translap!!)
    Which 1 will come out to play for the National??
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    What has been done to all the original yards of wiring when removing the fairing? Has it been shortened or tucked away somehow?
    Have you mounted replacement lights/clocks on the front subframe mount or is it all on the triple clamps?
    Some kind of quick(ish) change system between the 2 setups would be good, without permanent demolishing of the original setup.
    Leigh (& Saltburn!)
    Quote Originally Posted by Recycler View Post
    At the mo, the bike is just as quarryman (Mark) adapted it after it was dropped, no subframe, aftermarket headlight (which is crap!) mounted onto fork mounted brackets all the wiring is left stock & bundled up and hidden behind a plastic box bolted to a homemade frame.
    Revs, speed & fuel is looked after by an Acewell computer.
    It's funny but the bike feels wicked with no fairing, in a supermoto kinda way, less to worry about when on tracks, only disadvantage is sustained high speeds.
    It'll be at the National in it's current trim (before a winter makeover )
    I dare say the original clocks could stay with the subframe and just graft on an aftermarket headlight if you fancy going naked!
    For anyone interested, I have posted a couple of pic's on the post "Another New Bike" where you can make out the box hiding the tangled mess of wires
    '02 Transalp
    '98 Transalp
    '91 NC30
    Recycler's Avatar
    Cornwall
    Cheers Phil.
  1. Anyone Changed the gearing ??
    Last Post: 30-06-09, 10:04 AM
  2. gearing question??
    By shaneh in forum Varadero
    Last Post: 05-11-06, 02:13 PM
  3. Altering the gearing
    By Fentible in forum Africa Twin
    Last Post: 30-08-06, 08:20 PM
  4. Chains and gearing
    By Lord Stig in forum Africa Twin
    Last Post: 13-05-05, 03:37 PM
  5. gearing question??
    By DennisB in forum Chatter
    Last Post: 01-01-70, 07:01 PM
