Results 1 to 4 of 4
Thread: Blowing 30 Amp Main Fuse.
    andydavis1959 Guest
    Angry Blowing 30 Amp Main Fuse.
    My XL600V 1999 has started blowing its 30 Amp main fuse and I cannot track down the source. The 1st time it happened I replaced the fuse and it lasted about 40 miles before it blew again. It will now blow one every few miles.
    I have checked the loom for any shorts to frame, disconnected the heated grips but no go. In desperation to get myself home I put a bit of the heat shield tin foil from the inside of the battery cover across the blown fuse, I did get the 30 miles home o.k with full electrics but when I put another fuse in it blew again within a couple of miles.
    Can anyone help?
    Sparky is offline Member
    Fife, Scotland
    Re: Blowing 30 Amp Main Fuse.
    Have a check round all your connectors, might be damp gunge causing a short somewhere. Blast em all out with air from the compressor, i find that the best way to shift it.
    Other than that its a case of disconnecting less important items and running the bike till you isolate the short/low resistance. Have heard cases os relay coils on some bikes going faulty.
    S
    FatFergie's Avatar
    Mar 2006
    that's a big fuse to be blowing, have you checked your alternator?
    Loic's Avatar
    Loic is offline Member
    Reading
    Check for a short to the frame on the solid red and red with white cables at the fuse mount.
    If its on the red, its towards the ignition switch disconect and check between either end if thats good check the blue with pink and red with black between the ignition switch and fuse box (with all the other fuse in) it wont be past the fuse box!
    if its on the red with white then check between the fuse and the regulator/rectifier. The green wires on the reg/rec go straight to earth(frame). If that is okay then check the three yellow cables that go to the alternator.
    My bet is if not a chaffing cable then the reg/rec, honda have a habit of having dodgy reg/recs witch fail after about 7-8 years.
    any probs pm me with your number and I will talk you through.
    Hope it helps!!
    Loic
  1. oil blowing !!!!!!
    By R0vers in forum Africa Twin
    Last Post: 26-07-07, 09:30 AM
  2. that fuse that fuse that main fuse!
    By jabba in forum Varadero
    Last Post: 25-03-07, 10:44 PM
  3. Electrical Gremlins blowing fuses
    By quarryman in forum Transalp
    Last Post: 16-07-06, 01:06 AM
  4. Fuse box cover
    By Adjani in forum Africa Twin
    Last Post: 28-01-05, 08:57 PM
  5. fuse holder
    By SHARPY in forum Africa Twin
    Last Post: 02-09-04, 09:26 PM
