Results 1 to 6 of 6
Thread: Fork Oil
    tonygagey Guest
    Fork Oil
    How much fork oil ? Haynes says 542cc but is this for both forks or per fork? Help!
    Lumiya's Avatar
    Ziost
    Re: Fork Oil
    Remember that the amount of fork oil is dependant to if you did a full strip-down and can be different than if you're just changing the fork oil. Normally it's best to find the "distance from top of stanchion" figure which is a lot more accurate.
    Kymmy
    tonygagey Guest
    Re: Fork Oil
    Cheers Kymmy haynes states 141mm so giving it 140mm to be sure,rather have it stiffer than softer.
    Re: Fork Oil
    Quote Originally Posted by tonygagey View Post
    Sod's law means it will be each, so you have to buy 2 seperate litre bottles for the extra 84cc.
    babybadger's Avatar
    Mar 2006
    SE London
    Re: Fork Oil
    Which model Transalp? 650 or 600? Sounds like per leg to me. Make sure you get the airgap right.....600 is 125mm from top of stanchion with fork fully compressed and springs out!
    sproggy Guest
    Re: Fork Oil
    That volume of oil is definitely per leg, but as Kymmy implied you might get away with half a litre in each if you haven't done a complete strip-down. Having said that I've just changed the oil on a pair of used 650 forks and did have to break into the third bottle.
    If you can measure it accurately to 140mm why not do it to 141 instead (if it's a 650)? Honda spend a lot of time and money getting these things right so unless you intend to use the bike for purposes other than those it was designed for (whatever that might be) or have experience in damping adjustment you're better off sticking with the recommended figures.
  1. Fork oil
    By Mervinh in forum Dominator / FMX
    Last Post: 16-12-06, 12:11 AM
  2. Fork Gaiters
    By Dave O in forum Transalp
    Last Post: 02-06-06, 12:32 PM
  3. fork oil
    By eammonj in forum Africa Twin
    Last Post: 12-06-05, 09:13 PM
  4. what fork springs or fork mods?
    Last Post: 05-04-05, 08:13 PM
  5. Fork oil
    By redmarcus999 in forum Africa Twin
    Last Post: 14-03-05, 08:01 PM
